Hi There,
I currently have a 96 R33 gts-t, it seems to have a bit of black oil in the pipes eg. the pipes that connect the intercooler...
From what I have been reading, people are talking about the turbo seals being stuffed, is this the case? I have never had any smoke out the back (always checking)... Is it a big job to fix?
I also had my car back from a service and the mechanic noticed that an exhaust stud was brocken (from what I understand it was on the headers side, if that makes sense). Can anyone explain what this means, the mechanic told me I should have it fixed soon and it is a big job.... (3 months ago..)
This leads me on to my next question, can anyone supply me with a company name/number (in Sydney) that would be able to fix these problems, and perhaps an estimated cost of what I would be looking at?
And one more question, would it be worth it while the turbo is out, to have it high flowed???
Thanks heaps for your advice.
Rob
The oil has possibly come from the rocker covers. Fitting an oil/air separator can solve this (have a search at www.autospeed.com, they have a couple of articles).
The exhaust studs break because of differential expansion in the manifold. You will probably have to remove the turbo and manifold to fix. So while the turbo is out, may as well have it modded. I had a T3/T4 hybrid built - about $1700 from memory (in Melb tho, probably dearer in Syd)
Hi again,
Just spoke with a mechanic and he seems to be telling me it's turbo seal's that have gone.
Is ther eany way of confirming which it is?
I have found a oil/air separator for $95.00 with everything but don't know if it's worth it now.
I have OIL coming out of my Blow-Off valve dude...
I talked to some experts at XSpeed and they seem to think it's the turbo seals/gasket. I'm taking mine back to the dealer as it's under warranty, to see what they have to say about it.
It's worth having it checked ASAP dude :(
My oil seals on the turbo have been going for ages now..
Finally I am starting to see some oil that is coming from the bov recirc.
When cold it blows a little puff or two as it comes on to boost as apparently it leaks a little in to the exhaust housing or somthing?!?!? Not sure but that is what i've been told by a few ppls.
Running 15-16psi all day every day for god at least 6months now with no problems YET.. one day it will go pop... Hopefully I replace it before then though..
Is there any easy way to actually tell if the turbo seals are faulty when purchasing a second hand say HKS GT2530?!?
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
