Hey guys,
I have two T03/04 hybrid turbos for sale. The are both new, one is in perfect condition, and the other has a slightly scraped exhaust housing and a couple of fins got slightly furry ends. (damage in freight from overseas)
here are the pics:
I want $750 for the good one (will come with the manufacturers 12month warranty)
and $350 for the slightly damaged one (no warranty)
each comes with an exhaust side stainless pipe clamp as shown in pic.
Specs:
T04E TURBOCHARGER
"O" Trim
.50T COMPRESSOR WHEEL
STAGE IV WHEEL
T04 " O " T3/T4
.70 A/R TURBINE HOUSING
COMPRESSOR HOUSING A/R .50 TO4E
3" INLET
Rated to 500+ HP, cand handle 25psi+ easy
Standard divided Tang T3/T4 Flange and T4 footprint
Pics:
here are close-ups of the slight scrapes on the damaged turbo (only this turbo has this damage)
Pm me for any more details
I'm in brisbane, but can ship interstate.
I can source external wastegates and manifold quite reasonably priced too - anyone who buys these turbos I can hook you up with the right people for a good price.
I reccomend these turbos for a mid-modded RB20, and any RB25
I have seen these run on a stocko rb20 with a flange adapter to suit stock manifold - they have a big top end, and not too bad for cruising. Personally I reckon these are perfect for RB25's, but are good for an RB20 running high boost.
Chris
https://www.sau.com.au/forums/topic/62725-2-new-t0304-050070-turbos/
Well, as you can see these are quite a big turbo.
I have a friend who put one of these on a fairly stocko RB20, and it made boost around 5000-5500
He says the car is fine as a cruiser and good for the drags - probly not the turbo for you if you are into drifting.
If you plant your foot on the highway you will swing the back out in the wet - the boost comes on very hard and strong.
I reccomend this turbo for Rb20 if you plan to run over 14psi and have forged pistons planned for somewhere in the future.
I would say these turbos are more suited to RB25's as they have more low down grunt to get these turbos spooling.
My apologies about the size of the pics too - at least you can see full detail.
Any other questions, I more than happy to answer honestly and openly.
Chris
I believe they are branded "stone mountain racing", I have been told they use garret internals, but don't quote me on that.
these have now been advertised on ebay
** NOW ON EBAY!! CHEAP!! - MAKE A BID!!" ***
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...me=STRK:MESE:IT
grab a bargain, happy bidding
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
