Hey guys,
I have two T03/04 hybrid turbos for sale. The are both new, one is in perfect condition, and the other has a slightly scraped exhaust housing and a couple of fins got slightly furry ends. (damage in freight from overseas)
here are the pics:
I want $750 for the good one (will come with the manufacturers 12month warranty)
and $350 for the slightly damaged one (no warranty)
each comes with an exhaust side stainless pipe clamp as shown in pic.
Specs:
T04E TURBOCHARGER
"O" Trim
.50T COMPRESSOR WHEEL
STAGE IV WHEEL
T04 " O " T3/T4
.70 A/R TURBINE HOUSING
COMPRESSOR HOUSING A/R .50 TO4E
3" INLET
Rated to 500+ HP, cand handle 25psi+ easy
Standard divided Tang T3/T4 Flange and T4 footprint
Pics:
here are close-ups of the slight scrapes on the damaged turbo (only this turbo has this damage)
Pm me for any more details
I'm in brisbane, but can ship interstate.
I can source external wastegates and manifold quite reasonably priced too - anyone who buys these turbos I can hook you up with the right people for a good price.
I reccomend these turbos for a mid-modded RB20, and any RB25
I have seen these run on a stocko rb20 with a flange adapter to suit stock manifold - they have a big top end, and not too bad for cruising. Personally I reckon these are perfect for RB25's, but are good for an RB20 running high boost.
Chris
https://www.sau.com.au/forums/topic/62725-2-new-t0304-050070-turbos/
Well, as you can see these are quite a big turbo.
I have a friend who put one of these on a fairly stocko RB20, and it made boost around 5000-5500
He says the car is fine as a cruiser and good for the drags - probly not the turbo for you if you are into drifting.
If you plant your foot on the highway you will swing the back out in the wet - the boost comes on very hard and strong.
I reccomend this turbo for Rb20 if you plan to run over 14psi and have forged pistons planned for somewhere in the future.
I would say these turbos are more suited to RB25's as they have more low down grunt to get these turbos spooling.
My apologies about the size of the pics too - at least you can see full detail.
Any other questions, I more than happy to answer honestly and openly.
Chris
I believe they are branded "stone mountain racing", I have been told they use garret internals, but don't quote me on that.
these have now been advertised on ebay
** NOW ON EBAY!! CHEAP!! - MAKE A BID!!" ***
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...me=STRK:MESE:IT
grab a bargain, happy bidding
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
