R33 GTSt Auto.
Mods 3" turbo back, with 3" hi-Flow Cat
K&N air Fliter.
Turbo Smart 2 stage boost controller.
What seemed like a quick Dyne run started with the fact I had the wrong plugs 5's with should have been 6's.
So they were replaced.
Next the Oxygen sensor was stuffed, which I think was due to adding Octane Additive.
All that was sorted out and a after a 10psi run I reached.
172 Hp to the Wheels.
Does this sound, fair enough?
Also what does this convert to in KW's.
My best run when it was in stock form was 15.35 on the 1/4 when she was stock.
Do you think this enough to get in into the 14-15 second time.
Also whats the HP to Kw conversion:eek:
https://www.sau.com.au/forums/topic/6274-had-a-dyno-run-today/
yes, it all comes down to how the dyno is calibrated...there should be a universal calibration standard for these things
dynos wernt made for "out right" power figuers
i once got dynoed at 96rwkw :confused:
then another place at 400rwkw, so u see what i mean when these things arnt calibrated properly
and if the guy is saying "add 5% for a true figuer" just tells me that it aint calibrated properly
dynos were made for tuning
I had the dyno at Brisbane Tuning & Turbo, Wooloongabba.
There a honest bunch there and they said they reckon there dyno is out and reads about 5-10% under true HP/kW.
And I noticed that on the first few runs they had someone sit in the boot. But on the final one no one sat in the boot.
In the end the car feels lot smoother and quicker than when was stock.
Guest Nismo_Freak
250hp ---> 178rwhp... thats a 29% loss in the drivetrain if the car was stock!!!! An AWD Subaru only losses around 26%! There is no reason a RWD car should be lossing that much power unless power is reported too high (Ford always does this), or you have some issues with your clutch or differential. Or a bad dyno... or your car has some issues w/ compression and timing.
Nismo_Freak:
I've noticed that a lot of Americans quote incredibly high power figures at the wheels. I think it's just the dynos our two countries use. Our dynos (Dyno Dynamics?) generally show 70-75% of the fly wheel figures, whereas yours are a hell of a lot higher. I was checking out the Supraforums and they all quote unbelievable figures if they were on our local dynos.
Cheers,
Michael
190rwhp with stock boost, FGK cat back exhaust. Car in a decent state of tune. This was on a dyno day with plenty of other skylines, of standardish and modified types.
Some with more boost than me (10psi) and various other mods got the same rwhp as mine on the day,or slightly less.
You have an automatic, so you lose a few extra HP there before you get to the tyres.
Originally posted by MRE
So is that any good?
128kW at the Wheels.
The fellow said that there figures are down and to add about 5%, for true figures.
MRE, I have an auto as well and it made 138kw (190hp) at the rear wheels in totally stock air box, stock exhaust, stock boost. I had it up to 9psi now but didn't made any more power at top end, although I noted slightly increased in mid range. This is coz stock exhaust is very limiting, and I'm still waiting for my 3" exhaust delivery...
Yeah figures are always not the best.
I think you need to run on 3 diferent Dyno's to get a real idea.
Just got home from Willowbank test and tune and my best run was.
60ft 2.3
330ft 6.2
660ft 9.4
100ft 12.1
1/4 mile 14.3 @ 161.5 K.P.H
My best before the mods was a 15.3.
I'm happy
Guest Nismo_Freak
That Supra forums crap was a bunch of arguing and no point made. US #s are crap? I believe the real test lies in the 1/4 mile times to back up power figures. Ex.
SW Supra
T72 Powered Supra + Nitrous
804whp on dyno
9.81@153mph
Then a guy from the UK
650bhp
11s@130+mph
Sounds about right to me? Either way I know for a fact the aussie ---> american doesnt add up 100%. There was a blue r33 gtr on a dyno that layed down 600whp (when kw ---> hp) however on an american made dyno it layed down 852whp. Sounds like I should just add 30% roughly to the aussie figures. Which now makes sense to me ... 221whp US = 170whp Aussie
I know why:
US use DynoJet: Which is about 15% driveline loss RWD (Avg?)
We use DynoDynamics: Which is about 30% loss RWD (roughly)
So DynoJet is more accurate (arguably) and closer to flywheel HP hence higher figure :P
MRE: That dyno figure sounds a bit low, but you run the number, which is all that counts. You could get that 60 foot down a litte, and the MPH is good, so that is all that counts.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
