NF,
Yeah the thread I posted didn't really say anything definite, and a lot of crap was posted, but I just thought I'd post it to show dynos read a little differently around the world.
I also reckon the real power figures are in the quarter times. As long as the driving is consistent.
Cheers,
Michael
DYNO's ARE FOR TUNING!
There is no real point in comparing different dyno readings between cars on different dynos. Unless you are a bit bored.
If you are tuning your car , going back to the SAME dyno makes alot of sense.
The 1/4 mile is a sport and not a very strict indicator of power, there are even more variables than comparing dyno results. ie: if you don't get the right equipment to play the sport you may not do too well. Like playing golf with a hockey stick.
I guess asking for peoples dyno results with a similar car setup will give you a range, which if your car fits between can give you some peice of mind that nothing is terribly wrong.
What does doing a dyno run in a lower gear do to your figures? I assume the torque will read higher because there is more of a mechanical advantage, and the power will read lower because the engine is physically doing less work to get the extra torque.
Does anyone know roughly how much I should adjust the figures if the dyno run was done in 3rd instead of 4th? Assuming factory R33 GTS-t gearbox ratios (I don't know what the ratios are).
Originally posted by Duncan
I've just run today and I'm having trouble beleiving the results.
164rwkw from a R33 with 11psi, no other mods.
Seems way too high to me.  Perhaps its just blue cars make extra power.
Yeah right - blue cars !! he he
I reckon the extra Kilowatts came from the energy permiating from the two good lookin blokes in the back seat at the time of the run....:D:)
Seriously, with your sticky tyres and the extra weight in the back, I reckon there was less slip against the Dyno hence the better results. :cool::) (that sound like BS to me actually.)
Duncan , last time I ran there - I got 150rwrw with std boost and a cat back zorst - so a few extra PSI could make the 13rwkw diff, maybe ???
It depends on how the dyno is callibrated and what gear the run was done in. What was your torque out of interest?
Hi Jim,
Done in 4th gear. Unfortunately, the graph only has Air/fuel and power on it. I'm sure they logged torque as well, but I don't have the figures.
I think Broken got the figures for all cars, he might be able to post them. While good traction would have helped (definately no wheelspin there!), I suspect its a friendly dyno....
I dyno'd my car yesterday also (with Broken and 25 other Skylines)
Specs:
'95 GTS-T
Cat Back 3" Exhaust
HKS Air Filter
FMIC
2 Stage boost controller
First time i've ever had it done (only had the car 9wks)
7psi = 169 rwkw
12psi = 192 rwkw
Not bad for a first run , I was extremely impressed.
All i need now is a CAI, Side windors Tinted, oil change and my driver side window fixed and i think i'll just throw fuel in her for the next 3-4mths while enjoying the ride.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
    • Great weekend and event. Open fire at the caravan park, perfect weather all day and a great feed and a couple of drinks at at awesome country pub.
