ecl Posted January 27, 2005 Share Posted January 27, 2005 hiya been noticing my r34 is quite higher at the back than the front (by looking at the gap between tyre and gaurd/arch) so i am asking if its possible to just lower the back ONLY by like 1-2 inch or something (so the space between the guard/arch and tyre is decreased)? i'm scared that if i lower the front, the front bar that i want to purchase will scrap (even if it doesnt, i dont want to have the hassle of being overcautious over every bump on the road) thanks Link to comment https://www.sau.com.au/forums/topic/62753-re-lowering-the-back/ Share on other sites More sharing options...
Scooby Posted January 28, 2005 Share Posted January 28, 2005 ecl; be wary. 1-2 inches is a lot to lower the car and will affect the balance. you will shift the weight rearward and likely create an understeerer that you probably won't be happy with. you'll also affect braking as there will be less weight transferred to the front. scary. that's why, if you read various threads by Sydneykid and others, you'll see cars are properly lowered at both ends. Link to comment https://www.sau.com.au/forums/topic/62753-re-lowering-the-back/#findComment-1183443 Share on other sites More sharing options...
Scooby Posted January 28, 2005 Share Posted January 28, 2005 ecl; be wary. 1-2 inches is a lot to lower the car, particularly if it's only at one end, and will affect the balance. you will shift the weight rearward and likely create an understeerer that you probably won't be happy with. you'll also affect braking as there will be less weight transferred to the front. scary. that's why, if you read various threads by Sydneykid and others, you'll see cars are properly lowered at both ends unless you really know what you're doing are comfortable lowering one end only to achieve a desired affect. Link to comment https://www.sau.com.au/forums/topic/62753-re-lowering-the-back/#findComment-1183447 Share on other sites More sharing options...
