rb25 head mods, injectors and cam gear
CEF11E
 Share
I just picked up an rb25det head for a rb25/30 conversion but it didnt come with a fuel rail or injectors so i am after an opinions as to whats the cheapest/best way to go.
I dont know witch ecu i will be using yet (either rb25 or rb20 chipped) but i havent bought one yet.
so i dont know about high or low impeadence.
I am aiming for 250rwkw. Whats the best cheapest setup?
will i beable to convert a rb20 fuel rail to the rb25 head and fit gtr injectors?
or is the stock rb25 injector capable of supporting 250rwkw?
how much should i pay for a fuel rail and injectors?
S15 Injectors are sidefeed and will support up to around 270rwkw.
I wouldn't like to lean on the stock rb25 injector for a long period of time.
If you want to keep the VCT it looks like you are going to be looking at wiring in a R33 PowerFC. Grab a copy of the R32 & R33 Wiring diagrams from the engine manuals.
There's isn't much difference but there are a few critical differences.
i.e Injector signals are different pin outs.
 Share
    • Luckily I haven’t bought one yet but I’ve had several people tell me different things and was trying to find out what’s going on with my car lol apparently type m had different lover knuckles like the gtr but someone put non type m knuckles on mine Ok on another topic does anyone have a spindle for sale mine is screwed bad lmao
    • The vendor you bought from is a dickhead who can't tell the difference between AWD and RWD bearings. Their eBay listing is one of the first hits too, and is wrong. Any other hit shows the ones that are on your car. A search for GTR rear wheel bearings, unsurprisingly, finds the one you have from Shift. f**king muppets.
    • Got the flat door cards "good enough" for now. After cutting out the arm rest I removed all the stock trim material. Then filled the gap with a bit of Masonite and wrapped it in some adhesive foam to hide the  transitions as much as possible. Then I applied some black vinyl material to the panel with some spray on contact adhesive smoothing the edges as best as I could. Here is how it sits in the car with the door handle and cut down window switch mounted
    • Ok so I have a little bit of an issue. So I have a 1992 r32gtst and trying to replace the rear wheel bearing and spindle the research I’ve done shows a different style bearing than what is currently on my car. So the picture of the new bearing with the box says it’s the correct bearing as does my research but the picture shown of the old bearing is the one that came off the car. I’m a bit confused the new bearing has an ear on it that I’m assuming goes to where the top of the ebrake shoes mount as to where my old bearing does not. Any help would be awesome
    • What in the absolute mind f**k. Generally speaking, you cannot diesel a petrol engine without sparkplugs which you don't have since you're disconnecting battery.... Something is very fishy here.
