I have just cut the side off an RB26 box and welded it up.. the RB26 box is still longer and may require a little tap under the tunnel to fit.
Quite hard to weld it up.. would require good fab skills and time to make it work well.. I basically closed the whole transfer case part up.. also need to check for leaks etc before using it.
I believe you can also bolt on an Z32 nose cone.. but you would need to sort the shifting mechanism... as the Z32 uses arms.
https://www.sau.com.au/forums/topic/62804-gtr-box-rwd/#findComment-1184503
