Hi guys
Im contemplating throwing nos into my car cause i can get a real good deal on any HP shot (full system) OZ NOS setup?
MY rb25det, is pretty stock @ the moment (internals) other than 3" turbo back, fmic, ems, 550cc injectors, fuek pump etc...
What HP do you guys recommend, & if so, what should i have done to the motor to not fry itself...???
& I wont be using it much @ all, only on the track once or 3 times etc...
https://www.sau.com.au/forums/topic/62812-nos-system-wetdry-for-rb25det/
Single fogger wet system, running a 50 shot I think or a 75 hahaha one or the other, be careful though the oz nos system looks like good value but when a NOS brand single fogger wet system is only $850 now with a 10lb bottle its hard to go past as the oz nos comes with no bottle
Brett
Brett
say i buy the real "NOS holley" setup , with everything....is it still cool to hook it up & use it only once every while? like @ drags etc.,.
& being in nsw, can i cruise around & not get done by cops as long as i dont have the bottle in the car yea?
Mate its the single fogger wet system you need as the holley set up is for a carby, yep as long as the bottle isn't in the car you'll be fine and yep its fine to use every now and then you might just need a after market ecu to be able to take a couple of degrees of timing out if you plan on running anything bigger then a 50 shot
All testing should be done on a dyno though to check if it needs it or not
Holly make systems for Fuel injected cars as well as carby systems.
You shouldnt need an aftermarket ECU, just set the mix correctly.
Correct me if im wrong, But if your running 550cc injectors should your car have an aftermarket ecu? It would be over fuelling to the shithouse as the the stock ecu is already programmed to run rich mixtures?
Is it really that safe running NOS without Aftermarket PIstons?
Is it safe to increase boost without aftermarket pistons ?
There comes a point for any engine where enough is enough. The rb25det seems to be OK up to 250rwkw, so an extra 75hp of NOS at this point might be pushing it too far, but if you are only putting out 150-200rwkw, then a shot of NOS is probably your cheapest way to get that much power.
if you can use a diffrent brand it would be ok.
i had a faulty nos solanoid with my very first nos setup . it was a OZNOS type wetkit and the nos solonoid didnt shut so even though i had the switch of it was still throwing nos into the motor :( lucky i had a passanger that could reach the bottle and turn it off.
since then i have had two NOS BRAND kits and never once had a problem.
good luck with what ever you end up doing.
Hey guys - dirty-cheaterer-pusseh here :(
I run a 75hp NOS brand wet nitrous system using a single fogger plumbed between the factory BOV location and the throttle body.
It works great. Boostn247, dude, just come to myhouse and have a look. Bring your notepad and a pen ;) Gimme a buzz - 0416271834
Adrian
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
