Hey Guys
This is my first proper thread and i was wondering if you could help me out. My 95 GTST came with a wolf 3d v4 that was once hooked up but then taken out due to the coils breaking down. Im getting some new coils soon and just got some questions.
First question: Does the wolf retain its memory even after power has been disconnected?
If not leads me into my second question
Second question: I was wondering if anyone else has had a wolf 3D tuned in the Sydney area and are happy with the results and would recommend their tuner.
Thats all i can think of now. Appreciate anyones help :P
https://www.sau.com.au/forums/topic/62820-question-on-wolf-3d/
  OFENSV said:
it wont lose its memory, i have a wolf and had my tuned by croydon racing development in silverwater
Cool thanks for the reply. So i should be able to plug it back in and it should work hopefully :P. Also you were happy with the tune from Croydon racing development. :P
The wolf certainly wont lose its memory. You have to make changes via the controller or laptop in order for this to happen and this wont happen by accident. Get some new coils, try to start it, dont boot it cause you dont know of the previous tune, whether it was done by a numbskull or someone as skillful as Matt Spry. So best take it for a dyno run to make sure A/F ratios are safe. Small bother, but could save you big dollars if there is something wrong. Contrary to many people's opinions, the Wold3dv4 is a very good unit and I run one in my car. Plus its affordable.
Thanks for that. Will do. I ve had it sittin round for a while now and getting keen for it to get hooked up . Do you reckon i should just drive stock ecu to tuner and get them to put it on the dyno and get them to hook it up. Or is there a way to check the a/f ratios without putting it on the dyno :confused: . Take into consideration i know nothing about tuning etc. I mean will it come up on the hand controller. Where abouts is Matt Spry located. :rant:
  Kristov said:
Thanks for that. Will do.  I ve had it sittin round for a while now and getting keen for it to get hooked up . Do you reckon i should just drive stock ecu to tuner and get them to put it on the dyno and get them to hook it up. Or is there a way to check the a/f ratios without putting it on the dyno    :confused: . Take into consideration i know nothing about tuning etc. I mean will it come up on the hand controller. Where abouts is Matt Spry located.   :D
Matt Spry is located on the Gold Coast in Ernest. If you need his number, ask me and I can give it to you.
I would have your car towed to a reputable tuner as driving on the Wolf start map was impossible for me and who knows what damage you could do to your engine by running it on an unknown map. You can get cheap A/F ratio meters but they're not accurate. The wolf actualy has function for this now. So you can do it this way and this should be quite accurate. It should be good enough to get your car up and running if you know how to and are risking to tune it on the road (read dangerously stupid). Bite the bullet, take it to the dyno first up, save yourself a lot of hassle and trust me that you'll be one happy chappy when your car goes hard after the tune and you alive and have your licence.
Cheers
Thanks for the replys 180bfj20det. I probably should have mentioned that its is running the standard ecu atm so im just getting around on that. Matt Spry is located in Gold Coast. Thats a bit far for me im in newcastle but i will do some searches and try to find some good tuners in sydney (ones that other people would recommend). Not too keen for anyone in newcastle heard and read a few posts and most people say their pretty sh1t. Coils should be here in a couple of days finger crossed. :D
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 馃檪 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
    • Welcome!  Can't go wrong with a Stag.
    • Looks good. Nice height.
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
