Automatic Transmission Shift Kit. - Updated Oct 2006
Are these prices going to be a continual thing or just for this group buy? I'm installing a R34 RB25 and auto box into my HR31 Skyline and would be interested in getting the box beefed up slightly but it wont be ready for about a month or so.
Cheers,
Allen
I think you will be OK for the next few weeks (so long as others are taking up the group buy - cos I can see it taking a week or so turn around for each block of 4 Mike can make)
So who has rung up for this already.
I have! Sent the fax and all first thing monday
Also getting a transmission oil cooler kit
Will call them again soon just to make sure all the paperwork is done ok
after all this... Im actually still a bit blur to how a new valvebody actually improves the gearbox's durability and shift quality... :confused:
Valve body - controlls the pressure and timming for gear changes. The higher the pressure the faster the gear change.
Durability - Slower shifts mean that the bands (clutch packs) slide together much slower, thus more wear and heat, but very smooth. Fast shifts are a little less smooth but produce less wear on the bands and less heat.
Ill be calling up and ordering mine later this week, ive just moved out so thing have been pretty hectic lately
im still in though, and those to install make sure you post up a report for everyone
Excuse my ignorance but where does the valve body fit on the auto gearbox. Is it a gearbox out job?, if im correct i have taken off a couple oil pans on various transmissions and when you remove the pan, the valve body is right there? hence its a pretty easy do it your self job?
Also can someone calling mv ask what modifications he recomends to handle 280-300rwkw range? Will a tranny cooler and valve body be enough or is there a lot more to do.
So the trans cooler kit is $187?
do you know what size the cooler is?
I havent ordered mine yet, will do so next week, ended up getting food poisoning from fasta pasta on valentines day :cheers:
I think it was 29x22x2 or something like that. I think there is a difference between the oil and transmision fluid coolers but don't quote me on that.
$187 is a OK price for the whole kit.
LOL at getting food poissoning for Valentines. :D What a way to finish off the day.
LOL at getting food poissoning for Valentines.  :rolleyes:   What a way to finish off the day.
lol tell me about it
mod your car have some decent priced coolers aswell, http://www.modyourcar.com.au/?cPath=5_272
was thinking of upgrading and putting the trans cooler in a better spot considering i wacked a big ass intercooler infront of it last year :Oops:
I just checked and its 280x220x15.
I saw those coolers on ModYourCar and I'm not sure if they are the same thing coz those are 50 mm thick.
I think the one they're selling is something like the one in the pic.
I'm not sure how good are they.
i got a B&M cooler kit from autobarn for about $140 comes with all brackets hoses clamps etc and looks alot stronger than the others like yours pictured so wont bend fins etc
model was 70264
The PIC was juust an example what I think the cooler will look not the actual thing. I'll speak to Mike and check what kind of cooler it is.
I don't know much about these so I'm not sure what to look out for. All I know so far is the dimensions and that the whole kit is included.
How big is the standard cooler? I got an R32 and it doesn't have a cooler at all, it only goes thru the radiator.
My credit card has been charged on Friday so I hope I'll receive it soon.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
