Automatic Transmission Shift Kit. - Updated Oct 2006
HAHAHAHA yeah that seems about right. What I did was put a drop sheet on the floor and had about 6 saturday papers spread outso it was nice and thick to absorb anything. Nothing to stop it dripping and running down your arms though.
I ended up using 7.5 - 8 liters of HiTemp.
Adam - I have a full unopened canister left over so if you decide to go with HiTemp you can do me a favour and get it of me. :P Let me know.
I've got about 3/4 of one left over from last time. How many litres are in a container again? I know it's measured in Gallons but I can't remember how many of them either.
Also waiting to decide about Racing ATF. Might mix them. I know you can do this.
At any rate, I may just help you out ned. Will let you know in the next week.
haha yer i got fluid ALL over me and the garage floor :D
i just used 2 skyline jacks on wood with a hydraulic jack on the diff to raise the car prob 50cm off the ground
its not that hard to do if you got a good brain :(
haha yer i got fluid ALL over me and the garage floor :(
needless to say... i dont have a good brain
Wow. Mine looks quite different to yours but I guess that in terms of unbolting things it's similar. Most of my photos turned out crap. Either too much light or not enough. Very annoying.
This is the only decent one I got and it's of the top of the valvebody so you can't really tell the differences I'm talking about.
It looks like the scene of a murder.
Well I'll never know exactly what the vb will have given me because I am putting in a new turbo at the same time. If I could have I would have done them separately.
  • 3 weeks later...
Ok the kit is in and it works fine.
Basically the bolts you need to remove to get the thing out are all around the outside. If you look up near the gear shift lever mechanism you'll see that there are about 3 that don't need to be removed.
Also, you'll need to remove the sensors and stuff which I think will take care of the few bolts that are not around the outside that hold it up.
Mike told me there were about 7 bolts holding it up but there are more like about 15-20.
The welsh plugs that you put in go in the middle two holes of the four. I sanded them ever so lightly with 1200 grit sandpaper because I couldn't for the life of me get them in otherwise.
Three springs come out but only one goes back in. It's the lightest (ie easiest to compress).
I needed the jack to compress the spring enough to get the valvebody back in.
Use some longer bolts in the shorter bolt holes to get some bite and get at least 4 or 5 in before you start ratchetting them up because you don't want to strip threads.
I wrote down a little map with the numbers that are on the bolts on it but that didn't take into consideration the fact that there are 3 different lengths of the ones labelled '7'.
It's not a big drama in the end which bolts you use because when you have most of them in you can tell that some are too long so you swap it with others one by one.
Overall it was very time consuming because there are shitloads of bolts and they are many different lengths.
Ok how does it drive?
It is less likely to creep forward if you let off the brake at idle. More likely to roll backwards a little down a hill without brake.
1st to 2nd jumps in quite firmly now. Noticeable but not uncomfortable at low speeds. I am yet to redline it to see if it chirps but been close although I have semi slicks on at the moment. This is the most improved area I think.
2nd to 3rd firmer but still fairly smooth. Not as firm as 1st to 2nd.
3rd to 2nd, very firm.
3rd to 4th, much better at high speed, no firmness but still quicker at street speeds. Changing from 3rd to 4th at about 180km/h it securely and immediately went into gear whereas before it would take almost 2 seconds to slide in.
I dont get chirping, and damn well i shouldnt with full handling and camber kit plus falken semi slicks
from first to second does straife the tail out in a straight line if running higher boost and from standing start
although after having my car tuned i took the exhaust from the frontpipe back off for some testing and gasket replacement and wow was it fast! Flooring it in 2nd going about 60, car just kicks back and powerslides for about 15m
so i currently have the entire exhaust off for a revamp :rofl:
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
    • I'd say one thing that may make you sell is the same reason the guy with the hard top roof sold his. He got old, and his back was giving him too much grief stopping him getting in and out... Old guy said he was 73! He looked and sounded younger than 73 to me! Or maybe I'm just aligning with old people more...
    • Already looked at a few prior to getting the MX5, really nice car, had all the mod cons, but I wasn't really sold on the new "look" I did miss my 2017 Limited, and I personally prefer the "look" of the older car over the new model, but, when pondering I kept going back looking at MX5's But it was same same for the new ND's, I wasn't sold on the new "look", especially the RF with its weird roof, which only half goes down, like a targa top sort of thing As I stated before, I did look at NC's, but the cars I looked at were PRHT's, but I didn't like their roof line "look" of the PRHT, until I saw the soft top version, (someone on SAU posted a for sale ad for one with a soft top that caught my attention, you can blame them for my choice.....🤣) and.... that old style detachable hard tops were available for them, which keeps the old MX5 more smoother flowing roof line, and the more rounded body style, similar to the NA-NB, to me, the arse end of the ND looks to "modern" Much like how I prefer the NC1 front bar, over the later models How long will I keep this car for is unknown, but currently, there's nothing else out there that "floats my boat" for a small, fun, little "sports car", that I can play with and enjoy looking at and driving But, who knows what the future holds, and going off current new car styling, if I replace it, it will be a older model something something
