Automatic Transmission Shift Kit. - Updated Oct 2006
That sounds about right to me.
I now have a fully rebuilt transmission in mine.
how does it drive now?
did u get it rebuilt by MV Automatics?
exactly what is involved with a full rebuild?
and, by any chance did anyone replace their standard trans oil cooler?
if so, im in need to replace my standard trans oil cooler. just PM me thanks!
Drives very nice. Stock like when driven sedately. Harsh when driven hard. It is different though. Say you accelerate in 2nd to redline then let the throttle off but stay in 2nd. You don't get engine braking. The rpm just drops down to about 3k.
New bands, uprated servos, carbon kevlar bits apparently.
MV built it.
MV is in sa, i would assume that the r34 price is same as the group buy price. Mike gave me the group buy price for my z32. For those doing the vb them selves dont do the silly thing i did and leave out the selector ;). Many thanks to abo bob for helping me with this prob over msn ;).
Shift kit is awesome, i have tried out many things with my car running manual ecus, hks auto line controllers and nothing comes close. While they did a good job shifting firmly they did not respond fast enough, ie. i would always bounce off the limiter when manualy selecting from first to second. Now with the stage 2 shift kit it not only shifts even harder but is much more responsive, i can easily shift the gears manually with just a bit of a delay from when i move the gear stick. Like to thank 4door_Sleeper for organising and mv auto.
I rang mike on Tuesday and ordered one, and he called back Wednesday to let me know it was shipping out ! Really nice bloke, easy to talk to. Will report back next week once i fit it..
Gary
hi guys...
its good to see so much interest in our shift kits...
i hope they are all going well
for you who dont know i work their with mike i have been their for just over 2 years now..
we do these kits all the time and highly recomend them.
i have one in my r33...
from gary
Changes are smooth when light throttle 3-3500 rpm other a bit of a bump but at heavy throttle and highers revs it's back to pretty smooth.
The thing now changes faster than the computer is expecting so the revs drop a bit much sometimes.
the revs drop a bit much??
hmm it sounds like the 34 gearboxes dnt like the shift kit as much asthe 33??
abo bob do you think it is worth getting the kit?? seeing as you blew your box when you put it in i am a bit worried?
has any one else on here put it in a r34 tiptronic or just abo bob
Yeah that probably helped it. lol
so you are happy with the whole package?? i drive a large distance to work and need it to still be smooth when being driven normally.
you said something about it dropping revs too much?? are you using standard ecu?
sorry to ask so many questions but seeing as you have already done it i may as well ask.
yeah I'm in the same boat as mad34, but I am also going to get the high-stall modified while Mike is in the box. Are there any known negative side effects on life of the box or components etc? Later on I am going to get kevlar disks etc put in to fully strengthen the whole box.
Hi Andrew
Quicker shifts prolong the life of the clutch packs as they spend less time grinding away on each other. They also reduce the heat generated which is the big killer of autos. Make sure you also get a trans cooler fitted.
If there is enough interest we may be able to set up a group buy on the modified torque converters. (I am happy to talk to mike about this if there is enough interest - and as I need to do it to my 33 soom anyway.)
the 34 has a trans cooler fitted stock - I assumed all Skylines do!
I am looking to upgrade the cooler to a larger and more efficient one shortly anyhow.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
