Pulp Posted February 26, 2007 Share Posted February 26, 2007 Quicker changes will reduce the wear of the auto cluches and reduce heat, so it will improve the life of the auto (not reduce it)A trans cooler will cool down the oil (heat that comes from the torque converter) and will also help improve the life of the auto. Thanks mate I'm thinking of getting one, I noticed Stinks post about it being a bit harsh for what he wanted. Is the stage 2 that he has the same as what you guys have installed? Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-2937139 Share on other sites More sharing options...
the stink Posted February 26, 2007 Share Posted February 26, 2007 Quicker changes will reduce the wear of the auto cluches and reduce heat, so it will improve the life of the auto (not reduce it)A trans cooler will cool down the oil (heat that comes from the torque converter) and will also help improve the life of the auto. It may reduce the wear to the friction surfaces but the shock loads on the drivetrain are now a lot higher. From what i hear the diff and gearsets in the transmission are pretty strong but i'm sure it would reduce the life of these to some extent. Uni joints would be the things to keep an eye on. But in the end i guess this is no different to any other mod you do to your car, there is always a longevity penalty to be paid for performance. Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-2937468 Share on other sites More sharing options...
WazR32GTSt Posted February 27, 2007 Share Posted February 27, 2007 mine was the stage 2 kit and i find it awesome.. it depends on what you want out of your gearbox.. want a stock car that survives forever? stick with stock... want a performance car that you've modified? get a shift kit... i didn't get it to make my passengers more comfortable or to increase the life of the trannie.. i got it to make my gear changes intstantaneous Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-2940004 Share on other sites More sharing options...
slo-a31 Posted March 2, 2007 Share Posted March 2, 2007 how much power/torque are you guys putting thru your autos without any dramas? also does anyone know how much a rebuild kit wcosts? bands,clutches,gaskets etc? Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-2948977 Share on other sites More sharing options...
WazR32GTSt Posted March 4, 2007 Share Posted March 4, 2007 i have been running from 155 - 170rwkw through my box for about 2 years now and i don't drive it easy my auto hasen't missed a beat, but i do service it every 20,000kms Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-2952230 Share on other sites More sharing options...
slo-a31 Posted March 5, 2007 Share Posted March 5, 2007 sounds good what does the plug in box i seen do? anyone running around 400hp? Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-2954494 Share on other sites More sharing options...
4door_Sleeper Posted March 5, 2007 Author Share Posted March 5, 2007 anyone running around 400hp? Mine runs around 250rwkw and was the first on the forums to be modified. (over 2 years now I think) Still going strong, and an otherwise stock auto (no clutch packs etc yet, but I will put them in later when it gets tired) Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-2955189 Share on other sites More sharing options...
slo-a31 Posted March 6, 2007 Share Posted March 6, 2007 ok thanks for that. anyone have and info on the electronic box i think i seen? Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-2957819 Share on other sites More sharing options...
pkblade Posted March 6, 2007 Share Posted March 6, 2007 My auto is still good with a tick over 200rwkw for the past 14months & that's with a sequential manual-auto. Mike from MV has used one of the SA forum member's cars as a test bed for the RE4R01A & with supporting mods (ie. bigger ATF cooler, shift kit) the stock trans is good for up to 300rwkw (402rwhp). anyone have and info on the electronic box i think i seen?Are you referring to MV's magic black box? (Electronic shift controller)If it is, it connects to & disables the auto ECU. It permanently makes it like a manual valve body - requiring full-manual shifts. Also, the line pressure needs to be increased for things to shift properly. Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-2959151 Share on other sites More sharing options...
slo-a31 Posted March 8, 2007 Share Posted March 8, 2007 so would you be able to switch from a full man-an auto if you could switch that box on and off? Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-2964692 Share on other sites More sharing options...
sxc33 Posted April 5, 2007 Share Posted April 5, 2007 Group buy still on??? Anyone inquired about a stage 3? Of course tomorrow is good friday so i wont be able to call til prob tuesday ish Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-3032665 Share on other sites More sharing options...
4door_Sleeper Posted April 6, 2007 Author Share Posted April 6, 2007 Yes. Just ring Mike on Tuesday. Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-3033142 Share on other sites More sharing options...
redevil Posted April 6, 2007 Share Posted April 6, 2007 (edited) yeah i'll be down in the next few weeks bit short on funds, keep me updated and how easy are they to install yourself... and whats the difference between stage 1 and stage 2 Edited April 6, 2007 by redevil Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-3033149 Share on other sites More sharing options...
sxc33 Posted April 8, 2007 Share Posted April 8, 2007 yeah i'll be down in the next few weeks bit short on funds, keep me updated and how easy are they to install yourself... and whats the difference between stage 1 and stage 2 As was told to me when i asked the questions ages ago, stage 1 is for towing caravans and the like stage 2 is a performance valve body and recommended for the skyrine As to putting one on yourself, very messy from what i have read but reasonably straight forward. mPull the pan off, drain fluid, pull old valve body off and replace with new shiny one, pan back on. I am gonna give this a go Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-3036021 Share on other sites More sharing options...
naklaju Posted April 21, 2007 Share Posted April 21, 2007 I want the valve body and the torque conv but i'm not in aus...did they ship this to oversea? Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-3065600 Share on other sites More sharing options...
4door_Sleeper Posted April 22, 2007 Author Share Posted April 22, 2007 I want the valve body and the torque conv but i'm not in aus...did they ship this to oversea? I believe they do. I recall one skyline owner was in the UK. He had a few problems but Mike was great and helped him through over the phone. Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-3066501 Share on other sites More sharing options...
aquariuz6 Posted April 23, 2007 Share Posted April 23, 2007 Im curious to what is the difference between stage 2 and stage 3? Has anyone asked Mike yet? And what are the price differences between the stages? Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-3069622 Share on other sites More sharing options...
skidkid Posted April 25, 2007 Share Posted April 25, 2007 Been thinking of buying a shift kit for while. I have recently fitted a jacar boost controller (9psi low and 11psi high level) and being auto I am getting 2-3 psi boost spick beteen gears at times. I am thinking that with sharper change that will help eliminate/ keep spike down. Has anybody been down this track and what was the outcome? Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-3074740 Share on other sites More sharing options...
skidkid Posted April 27, 2007 Share Posted April 27, 2007 Heeello. Surely somebody has had the same problem as me! What is the best solution? Cheers. Don't boost to hard on a standard turbo!!!! Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-3080330 Share on other sites More sharing options...
4door_Sleeper Posted April 28, 2007 Author Share Posted April 28, 2007 I have never had a boost spike issue, perhaps its your boost controler or the length of the hose you use. Consider getting a decent one and see iof that fixes the problem. Link to comment https://www.sau.com.au/forums/topic/62854-automatic-transmission-shift-kit-updated-oct-2006/page/14/#findComment-3080849 Share on other sites More sharing options...
