Automatic Transmission Shift Kit. - Updated Oct 2006
yep me neither .... like Guy said I would be checking your boost controller. Even better plumb the wastegate actuator into the exhaust outlet pipe and see what boost your actuator is making on its own, and see if it spikes with it set up like that.
i ordered one of those "magic black boxes" to make mine a fully manual automatic...
i have a slight issue with the gear selection order, but called mike and he has given me some things to check, so off i go with the test light! hahaha
but i honestly cant recommend these guys enough... he has been really helpful with my issues...
the silvia i bought has been a wiring nightmare, so i'm not surprised if there is a wiring issue somewhere... the guy who did the conversion should be shot!! i had wires shoved into fuses in my fuse box... :action-smiley-069:
ah well... hopefully these wiring issue will be sorted out and i'll be back on the road... :thumbsup:
even though the gears are selecting in the right way, all i have to say is HOLY SHITE!!!
when it comes on boost in 1st gear it just frys the tyres and keeps spinning through 2nd gear... i thought i'd loose this when i converted from manual to automatic (yes, you read that correctly! :lol:) but i'm glad to see its still sweet... :)
Edited by S13 SecaBoy
  • 1 month later...
Hey, i understand that these available for the r34 tiptronic autos aswell ??...
i understand that it makes the gear changes alot quicker, but with the tiptronic, do the gear changes made via the buttons ont he steering wheel / gear stick (in tiptronic section) quicker aswell? or only good when left in D???
sorry for the Noob question but i couldnt find a mention of it
My understanding is that both the floor shifter and stearing wheel buttons will be a lot crisper.
To be 100% sure you should speak to Mike. (details on the first post)
Yes they are still available.
This is one of the advantages of dealing with a reputable long existing business.
As shown in the comments above the support and service you recieve is excellent.
  • 4 months later...
well i went to mike last week got me stage2 shift kit put in service etc u really notice the diffrence when u get in the cargear changes alot more firmer quicker and in 2nd it chirps me 19inch wheels so im very happy with his work highly recommend him top bloke if you have a auto u must get this!!!!!
Give him a call and mention this SAU group buy and he will look after you.
Initially this wasnt one of those "if we can get 20 people" type of group buys, but rather a deal I set up with MV Automatics if he could produce his kits for a discounted price.
I believe that they modify many types of auto-trans, some require valve bodies, others can be modified electronically - just call him and ask.
Hi,
so may somebody can help me to get one of this valve body upgrades for my Stagea?
I'am from Austria, does this company has an email or so?
and do the shipping to europe?
Thanks
Hi
I know that several people from overseas have purchased this kits, and were happy with theprobucts and after sales support.
I had a look for an email address but I cant find one, so it may require a phone call (08) 8370 0430 or a fax to get a price for shipping to europe. (or if u have lots of money i'll happily deliver it to you if you pay for my airfare LOL)
Edited by 4door_Sleeper
  • 2 months later...
hi there
i,ve just ordered/received the valvebody from mv autos, mike was very helpful and very quick on delv. ordered on the 6th jan, delv to me in the uk on the 18th jan >_< soon to be fitted.
i have 2 quick questions tho
1/ i take it no one has had any problems lately ??
2/ the auto box can take 400hp (298kw) max. what else can be done to take more ??
:D bruce.
  • 2 months later...
Hey im going to be buying one of these kits really soon ( car geting new tune this week so thinking its time for this mod)
MY QUESTION IS,
has anyone in Brisbane done this? and where did you take it to get done? prefably north side?
anyone?
cheers
Higher speed torque converters of between 2800 and 3000rpm are $410 changeover
which one would be good for my R33 already has stage 2 shift kit but what converter would you suggest going with.?
Cheers
Alan.M
Generally you'd want a torque converter to match your turbo & application (ie. city/ highway driving, drag). So, if you still have the stock turbo & street tyres the 2800rpm stall would be better suited as, the stock turbo will start to build boost at around ~3000rpm. Also, note that with most turbo engines the converter will have a flash stall higher than 2800rpm, so when launching it will be more like ~3300rpm.
:D
However, with the non-tip-tronic R32's & R33's if you maualise the auto you will loose engine braking in 4th & from 4th->3rd.
Hi there,
If you fit one of these to a R34 GTT do you still get engine braking when in the manual shift mode?
Regards
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
    • Got my 34 gtt tuned last week. Car made 362 wheel horsepower at 19 psi. Turbo was the ATR43SS. Only other upgrades were haltech 2000 series. 650cc injectors, walbro 250, fmic. Pro hub dyno reads 6% lower than actual figure according to my tuner. Car is a real ripper now.  IMG_7261.mov
    • Hi everyone, I'm wondering if anyone in Melbourne (preferably West) has a non-S2 R34 front bar. If it's already off the car, even better!  Nothing too weird, I just need to get a cut-out of the hole that the front indicators clip into 🤣 (image attached for reference)   I've got a front bar from JSAI Aero, but those holes need to be cut myself, and I want to get it right so the indicators will clip securely. And my OEM bumper is a S2, so I have no reference. So looking for a member who might be able to spare me a few minutes to make a cardboard cut-out using your front bar.
