Automatic Transmission Shift Kit. - Updated Oct 2006
Ive been speaking to mike for the last week or so and he has got valve bodies for r34's only prob is he only has a couple from what i understand and i know ones mine so get in quick or you will have to wait for ppl like me to send valve bodies back lol
I believe stock is 1800. To check this out put the car in Drive, put your foot on the break and gently press down on the accelerator.
The revs should quickly rise to about 1800rpm, then slowly up to around 2000rpm before the rears tyres start to spin.
Hope this helps.
  • 4 weeks later...
Just wondering like many others here, is there gonna be another group buy on these shift kits? Also can u feel the difference once these are installed? Is it ok for a daily driver or is it rough? Thx!
stock torque converter is 1500rpm, which can be taken to 1800rpm with foot on the brake
his ideal upgrade (that he recommended to me, thus what i have) is a 2800rpm converter, and can be taken just over 3000rpm with foot-on-brake launch ;)
The group buy is still running, just phone Mike at MV automatics, tell him you are after the Akylines Australia price on the shift kit / Torque converter or both, and he will send them out.
It is fine for day to day driving, (gentle pedal action) but you will notice a big improvement when you plant your foot quickly
Valve body arrived today with transmission cooler, just trying to figure out which auto workshop to go to, does anyone know any workshops in melbourne around the s.e suburbs which i can go to? and what price am i looking at to get it installed, trying to put in b4 friday because i want to drag it on friday. thanks any help much appreciated.
Put mine in last night
sending back valve body next week
so if you are after shift kit for your R34/stagea (tiptronic) get in quick
It was very easy to put it in
and makes going around corners interesting
so are you happy with it? does it feel better to drive? im putting mine in tomorrow and hopefully go to calder tomorrow night and see what it can do.
well the shifts are more direct now
no more flaring into gear
I bought it more for the life of the tranny
Ill be upgrading turbo ECU and Injectors soon so i thought i better try and fix the transmission side of it before i burn it out
any mechanic can put one in, its nto rocket science, just requiers a hoist and half a brain.. (ok maybe a quarter of a brain...)
getting it put in today for $220 with a service and the transmission cooler put on, and since i don't have a hoist and my car is to low to get on ramps i have no other choice otherwise i would have done it myself. i will let you know how it goes looking foward to getting it back, the auto shifts have always shit me the cars got the power but i agree it flares to much but i have always liked the way the car drives so hopefully if it doesnt flare and i will be really happy.
shifts are alot better no flaring on changes, very happy with it feels alot nicer to drive really have to play with the accelarator now it spins alot on gearchanges overall im pretty impressed.
the installation / removal photos have dissapeared from this thread, does anyone have any photos of this process, which bolts etc ??
Can I pay for an exchange, change it over once I recieve, then send my std one back to MV? Or is that, I will recieve a refund once I return my std valve body to MV?
What a frustrating day, i installed my shift kit, no go, wont engage any gears, but feels like its in drive not matter where the stick is, pulled it out, re-installed it...ahhhh, help me someone, i installed the lightest, thinnest spring on the end one where the black diaphram is, blocked off the middle 2 ports with welsh plugs, what else is there to do ? any photos or advice please.
Guest
    • Not a problem at all Lithium, I appreciate your help regardless. I've pulled a small part of a log where the target pressure was 28psi and it spiked to 36.4psi. I've only just begun using Data Log Viewer so if I'm sending this in the wrong format let me know.
    • Sorry had a bit of a week and haven't had heaps of time to follow this, so apologies if I've missed something - any chance of showing a log with the rpm, turbo speed, MAP, and wgdc all in one view? Definitely an "interesting" problem, and while it's definitely worth noting that there was a similar issue with the twins I'd not completely put all bets on the root cause being the same thing.  Keep an open mind, follow the data.
    • I built this engine approximately 12 years ago so my own head (brain) is a little grey on the exact hardware in the RB head, however what I recall is. Stock RB25 NEO TURBO Intake Camshaft HKS 260 degree Exhaust Camshaft (R34 GTR) RB25 NEO Turbo Springs  I ported/removed the exhaust stud humps found in the RB25 head so theres less turbulence but it wasn't ported/polished properly, just a hump removal. I've attached two pictures of the before and after to illustrate.     The ECU gets its boost reference from the nipple on the rear of the head on the intake side, behind the fuel rail. The wastegate gets its boost reference from a nipple on the cooler pipe immediately after the comp cover.  Could a decent pressure drop across the intercooler cause the wastegate to be seeing a higher PSI than what the ECU is seeing, and thus it can't control it accurately and quick enough?   We ran a line to the actuator and watched it open and close using an air compressor, while we didn't have a gauge on the line to see when it was cracking open, it was opening smoothly.  I just removed the gate now and even though the documentation says you need to open it in a vice due to preload (which I did), there wasn't any preload on the cap, which is something we noticed straight out of the box as well when new. This silver cap internally is threaded to the actuator rod that runs out the bottom of the straightgate. Not sure how I'm supposed to get this spring out to be frank.. Potentially but everyone else doesn't appear to have to stop at 500kw because of 6boosts design.  I would, but I think I'm getting to that point where if I'm going to do the head and make another 100kw, then I'm going to need a fancy gearbox and quite a few other things and 10k becomes 20k becomes 30k within a few months. I'm not necessarily sold on the idea just yet that the head is restrictive at 4000rpm (and what.. 300kw?) and yet doesn't seem to be restrictive at 7000rpm when it's making 500kw, however I'm obviously not closing the door on that theory.
    • Yeah - Half the problem is I know this sensor actually goes to 150C.. I'm pretty certain it is min of 11C. So still more data required I suppose. It's really quite hard to get the oil temp to 100+ then immediately pull over and take a reading before the temp drops. Annoyingly I suppose the range I really 'want' is likely 80 -> 120C. TBH the ecu can't really *do* anything with it, and the gauge itself is very visible... ...but you know how it is.
    • My EFR 8474 Black, made 800awhp on a roller dyno. at 25-26psi. E85. Shaft speed was around 106,000rpm 1.01 rear. The rear is maxed.  6 boost Turbosmart 60mm gate 3.5inch exhaust  Head is worked to the shithouse. Bain racing. VCam. 272 exhaust. RB28 - RB26 foundation.  You have an intake issue. Start getting proper data and I mean go back to the simple things.  - Pressure test your intake - Block off the Turbo BOV, you don't need it.  - Test pressure before and after your intercooler If your head is pretty stock, that is your issue. Especially if it is NA.  Take it off and spend $10k on it.
