Automatic Transmission Shift Kit. - Updated Oct 2006
Quicker changes will reduce the wear of the auto cluches and reduce heat, so it will improve the life of the auto (not reduce it)
A trans cooler will cool down the oil (heat that comes from the torque converter) and will also help improve the life of the auto.
Thanks mate :laugh:
I'm thinking of getting one, I noticed Stinks post about it being a bit harsh for what he wanted. Is the stage 2 that he has the same as what you guys have installed?
It may reduce the wear to the friction surfaces but the shock loads on the drivetrain are now a lot higher. From what i hear the diff and gearsets in the transmission are pretty strong but i'm sure it would reduce the life of these to some extent. Uni joints would be the things to keep an eye on. But in the end i guess this is no different to any other mod you do to your car, there is always a longevity penalty to be paid for performance.
mine was the stage 2 kit and i find it awesome..
it depends on what you want out of your gearbox..
want a stock car that survives forever? stick with stock...
want a performance car that you've modified? get a shift kit...
i didn't get it to make my passengers more comfortable or to increase the life of the trannie.. i got it to make my gear changes intstantaneous
anyone running around 400hp?
Mine runs around 250rwkw and was the first on the forums to be modified. (over 2 years now I think)
Still going strong, and an otherwise stock auto (no clutch packs etc yet, but I will put them in later when it gets tired)
My auto is still good with a tick over 200rwkw for the past 14months & that's with a sequential manual-auto.
Mike from MV has used one of the SA forum member's cars as a test bed for the RE4R01A & with supporting mods (ie. bigger ATF cooler, shift kit) the stock trans is good for up to 300rwkw (402rwhp).
anyone have and info on the electronic box i think i seen?
Are you referring to MV's magic black box? :) (Electronic shift controller)
If it is, it connects to & disables the auto ECU. It permanently makes it like a manual valve body - requiring full-manual shifts. Also, the line pressure needs to be increased for things to shift properly.
  • 4 weeks later...
Group buy still on???
Anyone inquired about a stage 3? Of course tomorrow is good friday so i wont be able to call til prob tuesday ish
yeah i'll be down in the next few weeks bit short on funds, keep me updated and how easy are they to install yourself... and whats the difference between stage 1 and stage 2
Edited by redevil
As was told to me when i asked the questions ages ago,
stage 1 is for towing caravans and the like
stage 2 is a performance valve body and recommended for the skyrine
As to putting one on yourself, very messy from what i have read but reasonably straight forward. mPull the pan off, drain fluid, pull old valve body off and replace with new shiny one, pan back on.
I am gonna give this a go
I want the valve body and the torque conv but i'm not in aus...did they ship this to oversea?
I believe they do.
I recall one skyline owner was in the UK.
He had a few problems but Mike was great and helped him through over the phone.
Im curious to what is the difference between stage 2 and stage 3?
Has anyone asked Mike yet?
And what are the price differences between the stages?
Been thinking of buying a shift kit for while. I have recently fitted a jacar boost controller (9psi low and 11psi high level) and being auto I am getting 2-3 psi boost spick beteen gears at times. I am thinking that with sharper change that will help eliminate/ keep spike down. Has anybody been down this track and what was the outcome?
I have never had a boost spike issue, perhaps its your boost controler or the length of the hose you use. Consider getting a decent one and see iof that fixes the problem.
Guest
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
