Automatic Transmission Shift Kit. - Updated Oct 2006
yep me neither .... like Guy said I would be checking your boost controller. Even better plumb the wastegate actuator into the exhaust outlet pipe and see what boost your actuator is making on its own, and see if it spikes with it set up like that.
i ordered one of those "magic black boxes" to make mine a fully manual automatic...
i have a slight issue with the gear selection order, but called mike and he has given me some things to check, so off i go with the test light! hahaha
but i honestly cant recommend these guys enough... he has been really helpful with my issues...
the silvia i bought has been a wiring nightmare, so i'm not surprised if there is a wiring issue somewhere... the guy who did the conversion should be shot!! i had wires shoved into fuses in my fuse box... :action-smiley-069:
ah well... hopefully these wiring issue will be sorted out and i'll be back on the road... :thumbsup:
even though the gears are selecting in the right way, all i have to say is HOLY SHITE!!!
when it comes on boost in 1st gear it just frys the tyres and keeps spinning through 2nd gear... i thought i'd loose this when i converted from manual to automatic (yes, you read that correctly! :lol:) but i'm glad to see its still sweet... :)
Edited by S13 SecaBoy
  • 1 month later...
Hey, i understand that these available for the r34 tiptronic autos aswell ??...
i understand that it makes the gear changes alot quicker, but with the tiptronic, do the gear changes made via the buttons ont he steering wheel / gear stick (in tiptronic section) quicker aswell? or only good when left in D???
sorry for the Noob question but i couldnt find a mention of it
My understanding is that both the floor shifter and stearing wheel buttons will be a lot crisper.
To be 100% sure you should speak to Mike. (details on the first post)
Yes they are still available.
This is one of the advantages of dealing with a reputable long existing business.
As shown in the comments above the support and service you recieve is excellent.
  • 4 months later...
well i went to mike last week got me stage2 shift kit put in service etc u really notice the diffrence when u get in the cargear changes alot more firmer quicker and in 2nd it chirps me 19inch wheels so im very happy with his work highly recommend him top bloke if you have a auto u must get this!!!!!
Give him a call and mention this SAU group buy and he will look after you.
Initially this wasnt one of those "if we can get 20 people" type of group buys, but rather a deal I set up with MV Automatics if he could produce his kits for a discounted price.
I believe that they modify many types of auto-trans, some require valve bodies, others can be modified electronically - just call him and ask.
Hi,
so may somebody can help me to get one of this valve body upgrades for my Stagea?
I'am from Austria, does this company has an email or so?
and do the shipping to europe?
Thanks
Hi
I know that several people from overseas have purchased this kits, and were happy with theprobucts and after sales support.
I had a look for an email address but I cant find one, so it may require a phone call (08) 8370 0430 or a fax to get a price for shipping to europe. (or if u have lots of money i'll happily deliver it to you if you pay for my airfare LOL)
Edited by 4door_Sleeper
  • 2 months later...
hi there
i,ve just ordered/received the valvebody from mv autos, mike was very helpful and very quick on delv. ordered on the 6th jan, delv to me in the uk on the 18th jan >_< soon to be fitted.
i have 2 quick questions tho
1/ i take it no one has had any problems lately ??
2/ the auto box can take 400hp (298kw) max. what else can be done to take more ??
:D bruce.
  • 2 months later...
Hey im going to be buying one of these kits really soon ( car geting new tune this week so thinking its time for this mod)
MY QUESTION IS,
has anyone in Brisbane done this? and where did you take it to get done? prefably north side?
anyone?
cheers
Higher speed torque converters of between 2800 and 3000rpm are $410 changeover
which one would be good for my R33 already has stage 2 shift kit but what converter would you suggest going with.?
Cheers
Alan.M
Generally you'd want a torque converter to match your turbo & application (ie. city/ highway driving, drag). So, if you still have the stock turbo & street tyres the 2800rpm stall would be better suited as, the stock turbo will start to build boost at around ~3000rpm. Also, note that with most turbo engines the converter will have a flash stall higher than 2800rpm, so when launching it will be more like ~3300rpm.
:D
However, with the non-tip-tronic R32's & R33's if you maualise the auto you will loose engine braking in 4th & from 4th->3rd.
Hi there,
If you fit one of these to a R34 GTT do you still get engine braking when in the manual shift mode?
Regards
Guest
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
