Automatic Transmission Shift Kit. - Updated Oct 2006
I got my package today and if everything works out it'll be in on the weekend.
I'll keep you all posted.
Also, I've started a new thread about possible gearbox problems i'm having.
Any help will be appreciated. Thanx.
http://www.skylinesaustralia.com/forums/sh...686#post1224686
standard cooler is tiny, about 1/3 of the upgrade
for those curious people
here's a pic of the MV cooler upgrade
got it today with the new valvebody
Awesome, ill be getting one of those too
Shift kit is in!
definitely tighter shifts... but a bit more brutal in my case since Ive got a wolf in as well, still within reason though
Will be sending valvebody back real soon
tomorrow or day after, its still soaked in oil
The trans-cooler also went in, too bad had to mount it between radiator and FMIC (stock location) would have preffered a better location.
So is it gentle at lower speeds still?  Can you please give us a more detailed description lukits?
At lower speeds it shifts like factory, I couldn't really feel any difference. But at high rpm, shifts are definitely more jerky, chirps the back wheels a bit in my case
Any figures on how much power the auto box can handle now with the shift kit and trans cooler?
My tuner has very little faith in them...
I beleive mike himself on zoom mag said 'With a good condition box and one of my shift kits.. 300kw)
Im about to call MV auto now and get things rolling
Also, did you install yourself lukits?
What about next to the pasenger side wheel well behind front clip where there is a slotted panel behind old IC (at least on GTS -Make some if not)? At least the air will be cooler going through it. A Fan would help as well.
No I didnt try to mount the valvebody or trans cooler myself
I dont think the lines that come with the trans cooler is long enough to have it mounted on the passenger side and besides my intercooler piping sorta blocks the airway from the front bumper slightly
i want 1 in about 1-2 weeks with service kit
Any other Gold Coast people wanna have it done at the same time to save on postage ?????
Called mv the other day and made an order, just waiting for some ppl to send their valvebodies back before he can send anymore out
my auto is starting to play up a little in 3rd gear, occasionally it drops down as if it was in neutral.. asked mike about it and he says its something to do with the engine or trans brake and it should be ok
still, im a bit picky and like everything to be perfect :wassup:
either way i have another auto sitting at my dads house ready to go in if this one breaks :(
anyone who needs somewhere to go in brisbane for auto work.. apparently Athena Automatics are pretty good, had a mate take his auto 180 there with a blown box and with a box he supplied they changed them for $2xx
ide imagine fitting a valvebody + full flush and new fluid (depending on fluid, i use full synthetic = $45 per 4L) wouldnt cost more than $100 max at an automatic specialist
everyone post up how their install went and details so the rest can be informed :P
also, has anyone actually broken their auto and have a new one put it or work done on it?
Sent valvebody back to MV yesterday
Ive used my shift kitted auto-box to the max yesterday from standing start to 6-7k rpm on 4th gear. It shifts nicely at full throttle even with wolf3d. My tyres are crap so it takes a bit of throttle control when shifting from 1st to 2nd to maintain traction.
But ive seem to have a problem with the geearbox computer, often esspecially when its warm, it shifts gears too early. In one run I would go up to 5000rpm and it would shift, other times at 5500, 6000, 6500. Any ideas why the auto box wont shift at 7000 all the time?
Have you tried using the POWER shift button?
I just read your post again and noticed you're using Wolf3D. I'd say that's whats causing the problem for you. The aftermarket computers don't work well with Auto boxes. They are no designed to comunicate with the Auto ECU.
The normal Auto computer has to comunicate to the main ECU. There's a few wires between them. The Auto computer retrives the speed and rev signals. Not sure about the rest.
Guest
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
