Automatic Transmission Shift Kit. - Updated Oct 2006
about 230rwkw. I think it broke gradually. It's been flaring 1st to 2nd for ages and as my power has gone up it's got worse. Also I've been to heaps of track days and overheated it once.
i do have a cooler for it.
I am going to get M V Automatics to rebuild it nice and tough. It will be much stronger when I get it back and should be shifting gears like a mother****er.
And we all know how good that is.
hi guys
i work for mike at mv automatics in adelaide
i am his apprentic and have been their for over 2 years now
i my self have just brought a r33 skyline
auto of coruse
just shift kitted it and its killer.
mike has been doing these kits for a long time
i my self think its a must for all you auto drives out their
i have driven many car making good power but have had shit shifts.
after fitting a shift kit different car a must for people making half diecent power.
the shift kit inproves the shift all thought the gears
also it is controlled but throttel
eg.the more you are on the throttle the harder the shifts gets
so at light throttel a great clean shift and at full throttel normally cherps.
also their are diffent stages we can go to sut your combo
eg.stage 1 satge 1.5 etc
hope this help you guys out.
if you would like to know more i will be happy to help you with
go the autos
Hi guys, I am hoping you can help me out here. I am in the UK and bought one of the VB's from MV.
My mechanic was installing the new VB and, got the welsh plugs in ok, but, when he came to swap over the 4 solenoids he found that the old and new VB's do not match up and I am stuck, looking at the 2 pictures can you tell me what the problem may be?.
FYI the gearbox is not the one off my car, I bought it as a spare, and it definately came off an RB25 Engine.
Any help would be greatly appreciated,
Cheers,
Jake.
Pic on the left is of the old VB, the new VB is the pic on the right
Hi Jake
I spoke to Mike at MV automstics today, but it seems you beat me to it.
(for the benifit of other mambers on the forums) He tells me you have basically got an R34 box (they put these in the last of the R33's) and that he has/will fix things up for you.
Let me know how things go
Guy.
Cheers guys, I do appreciate your help. I did speak to Mike yesterday, what a genuinely nice guy, very helpful, plan is to now install the VB tonight on the gearbox that is currently in my R33 which is an RE4R01A, will post up the results later tonight :D
Jake
.......and damn was it worth it .
Very very messy job to do, lots of things that can go wrong, but, the end result is an autobox that just does not slip between gearchanges, 1st to 2nd goes in with a bang and a thud, 2nd to 3rd the same, 3rd to 4th not so bad, the changes are lightning fast and, I have just had the pleasure of breaking the rears loose on the 2-3 change up, jeseus christ I love this shift kit :)
BTW, did anybody else reset their ECU after installing the VB, I did have 1 slight issue with the box sticking in 2nd and bouncing off the limiter without a change up, but, this could have been boost related (too high), then again, it could be the car just learnng the new shift patterns too.
All in all, very, very pleased with it :D
on a non shift kit related matter; i blew reverse
dont ask me how cos i dont know, it drops in revs like its in gear, but wont actually put any drive to the wheels no matter what revs :confused:
but got another gearbox sitting here anyways :uh-huh:
guess ill be putting the shift kit in twice
Is anybody else having an intermittent issue with the box not changing up after a hard kickdown?, I have had a couple of moments when it will kick down a gear or two then just bounce off the limiter and not change up?, it is fine when driving "normally" ;)
I havent heard of this problem with anyone else. I am not sure but could the problem be the kick down sensor? it may be forcing the auto down a gear when it shouldnt, and hence holding it down.
there is a compisit belt made out of kevlar and something else wich initates the drive of the gear box when it slips excesively it ither needs to be replaced or tightend
ps. dont open the cover of your auto and start tightining things the belt is set to a certian NM of presure leave it to a pro
Oh bloody hell i'm pissed off after all that trouble installing it, i put the car in d and it goes no where, basically wont engage in any gear. If anyone thats done it them self can give me some answers to where they put certain things that would be great because i can't call mike up until tommorrow. The two centre circles get plugged up with wesh plugs, 2 of those springs are removed and not used. The skinny long (softest) spring is placed in the hole closest to the engine. Heres wherei could have possibly been wrong, did u goes place that spring in the hole closest to engine or closest to tailshaft. Apart from that there was probly 1 left over screw but i think that was because it was already on the new vb. Any way would be great if someone can reply to the post other wise i'll find out tommorrow from mike and let you know how i go.
Guest
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
    • I agree, and yet my "HRM " hat is also on, as his wideband is in disagreement with the narrowband where they used to play closer attention to each other.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
