I know the R32 RB26 sometimes has oil pump drive problems that destroy the pump and crank if not fixed soon enough.
I'm not 100% sure of the cause or if the problem applies to the RB20 but both have problems with the bolts coming loose.
The R33 RB26 has a stronger oilpump drive.
Jun make an adapter so you can use R33 pump on the R32 crank but I think that is only for the RB26.
https://www.sau.com.au/forums/topic/62883-r32-oil-pump/#findComment-1185228
Yeah, i would say your mech, stuffed it getting the gear off.
I always just cut/split the timing gear, its too hard to get a puller behind it without damaging the oil pump.
Nissan part No. 13021 42L11
RRP $47.89
Just ring whoever your local Nissan dealer is, most have a spare parts department.
https://www.sau.com.au/forums/topic/62883-r32-oil-pump/#findComment-1186577
Its called a timing sprocket plate according to Nissan.
Nissan Part No. 13022 42L00
Its just a small metal disc to stop the belt sliding off. Should only be a couple of bucks.
Sounds as though he stuffed it, when trying to remove the timing gear.
Just confirm the part no. with Nissan before ordering.
https://www.sau.com.au/forums/topic/62883-r32-oil-pump/#findComment-1188000
  • 9 months later...
Hi RB30-POWER, how do you go about splitting / cutting the timing gear off with-out f'ing the crank and pump? Do you use an angle grinder or a chisel or what? This has been quite a pain for me!
The reason I want it off is to change the front seal on my 4WD RB20. I am told that I will not be able to get the pump off due to the bolt not clearing the sump. Advan (Silverwater) tell me that they slide the seal out with-out taking the pump out, then slide the new seal in. Does that sound fair to you? Any healp would be GREEEEAAAAT!
https://www.sau.com.au/forums/topic/62883-r32-oil-pump/#findComment-1737876
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
