Brake pads - even if you upgrade the discs and calipers, they will not make a 'huge' difference if you continue to use stock pads.
A killer set of jap pads make a massive difference - endless SS-S is my favourite for the fronts, very good initial bite, low dust, dont fade (well didnt up in the adelaide hills :P ) as they are rated to around 500 deg C. The difference of fitting a good set of pads cannot be over- rated.
If you want something for the track, then an upgrade to brakes and pads may be the way to go, but seriously, upgrade of the pads is a MUST either way if you want stopping power.
https://www.sau.com.au/forums/topic/62886-brake-upgrade/#findComment-1185330
Rears, once again any decent jap pad would do wonders. If you are thinking drift, a set of dedicated drift pads would be the shot - such as URAS or endless, they both do them.
Fronts are around $295 from D1 Garage, otherwise, check out greenline. Price would be similar as post is going to be a problems as they are heavy items to import.
https://www.sau.com.au/forums/topic/62886-brake-upgrade/#findComment-1185365
