Brake pads - even if you upgrade the discs and calipers, they will not make a 'huge' difference if you continue to use stock pads.
A killer set of jap pads make a massive difference - endless SS-S is my favourite for the fronts, very good initial bite, low dust, dont fade (well didnt up in the adelaide hills :P ) as they are rated to around 500 deg C. The difference of fitting a good set of pads cannot be over- rated.
If you want something for the track, then an upgrade to brakes and pads may be the way to go, but seriously, upgrade of the pads is a MUST either way if you want stopping power.
https://www.sau.com.au/forums/topic/62886-brake-upgrade/#findComment-1185330
Rears, once again any decent jap pad would do wonders. If you are thinking drift, a set of dedicated drift pads would be the shot - such as URAS or endless, they both do them.
Fronts are around $295 from D1 Garage, otherwise, check out greenline. Price would be similar as post is going to be a problems as they are heavy items to import.
https://www.sau.com.au/forums/topic/62886-brake-upgrade/#findComment-1185365
    • Hey guys I’m chasing a Rb20det complete or bare block need a good running engine as mine has low comp
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
    • 98 and 95 have to meet the same national fuel standards beside the actual RON.  91 has lower standards (which are quite poor really), so 95 is certainly not 91 with some octane booster. It would be an easier argument to claim 98 is just 95 with some octane boosters. Also RON doesn't specify 'quality' in any sense, only the octane number.  Anything different retailers decide or not decide to add to their 95 or 98 is arbitrary and not defined by the RON figure.
    • Anyone know alternatives to powerplus tungsten? Can't find an alternative online.
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
