When driving my car it will suddenly only rev to about 2500rpm and stay there even under full throttle. I am still able to drive the car, but only under these revs. I am able to turn the car off and on again and drive normally, but it is starting to annoy me.
Have been told it may be air flow meters, but the diagnostic didn't show an error. Current mechanic thinks it could be the engine wiring loom, but have you ever tried to get a replacement loom for a GTR to test the theory? They are like hens teeth.
Has anyone had this same problem and rectified it?
https://www.sau.com.au/forums/topic/62906-r32-electrical-problems/
hi, it sounds like it is running in limp home mode, possibly the airflow meters, car will run on one airflow meter but if both afms die then it reverts to limp home mode. was it doing anything else strange before this happened?
has anyone been working on the car prior to this happening and not connected something properly?
Are you sure the computer hasnt been modified at all?
have you checked the plugs that connect the afms to loom?
hi CS_180, before you get a new afm try fixing it, youv'e nothing to lose if you plan to buy a new one, afms have a reputation of 'dry' solder joints, my afm on my '32 played up - car was stalling without warning - and i resoldered the pins that lead to the plug(under the afm lid), search the threads there have been a few in the past. Mine is still going 3 years later and no probs since, even showed fine on the nissan consult computer.
if you find someone with a consult interface and can recreate the 2500 problem, then drive the car and fire up a consult program, youll quickly see which or if both afm is not working. you might even fine one is permanently dead too
then check for continuity (or visually inspect) the joints to the afm from ecu (find right ecu pins might be a bit tricky, but its probably in the service manual as one of the troubleshooting procedures.)
Car is basically stock except for exhaust, so no ecu changes. The problem started all of a sudden one night. Was driving along and it lost power briefly, didn't think anything of it. But then later on in the night it just died and wouldn't rev.
Have taken off one afm to see what condition its in, the other one is a bit hard to get to when car is hot, but will take it out when car is cool. Have bought two RB20 afm's to replace these ones, but not sure whether stock computer can run them properly.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
