ok its coming up onto the 200,000k mark and the motor is still boosting fine and running great. now my friend said when he does the belt he wants to change the front crank seal and the cam seals aswell. first thing - do you have to do them? is it better if you do and secondly how much do they cost?
any help on the subject would be great.
Thanks
https://www.sau.com.au/forums/topic/62916-2nd-timing-belt-need-some-help/
The seals are the same as the RB30/VL/R31 cam seals. (The oil pump also uses the same seal as the camshafts)
About $6.50 each.
If you want genuine you will pay around $15 each.
And as mentioned, do the water pump as well.
Im fairly sure the RB20 has the same pump bolt spacing as the local VL/R31. (The RB25 is different though)
Therfore you can get an aftermarket pump for around $88 (PowerMax brand - Made in Japan)
Genuine pump will be around $120.
Its a good idea to do the seals as they go hard overtime and score the crank and camshafts, this is what causes leaks on high km motors. To do the oil pump seal, you would have to remove the crank timing gear, which is a real bitch, often you have to split them and get a new one in order not to damage the oil pump ($49 for a new timing gear).
You should be able to do the oil pump seal without removing the pump itself. If you remove the oil pump, you have to drop the sump.
Hope that helps some.
cool. well i don't need a new water pump as i had one installed not long ago.. so with the crank seal thats the same as the rb30/R31/vl and what about the cam seals? same as all the other twin cam rb's
thanks for you input guys! :(
Just get genuine ones. You'll thank me later. If you go aftermarket you compromise quality with THIS particular product. Trust me I've been there. Three times now.
It's only a few dollars more and you can just give Nissan you VIN and tell them what you want.
The other thing is, when and where is your mate doing these seals. I wanna come and watch to see how he'll get the lower timing belt pulley off to get at the seal. With that particular seal, make sure you have all the equipment to remove it properly before starting coz if you don't, chances are you'll wreck something. Unless you know for sure that it will come off easily. I only say this coz usually it takes an oxy, a couple of big levers, a big hammer, a grinder, a claw puller, a brand new pulley in the end and every swear word you and your mate knows to get it. Let's just say that the neigbours will learn a few new ones. lol.
Good luck.
umm..... well.. i think i might just ask him if he knows what he's into.. he is a very knowledgable person that works in the industry but hasn't worked on a rb but everything else. lol... neigbours.. who needs em lol
    • I’m guess it’ll end up with a turbo
    • To install new hicas ball joints do i really need to pay for the Frenchys hicas install tool? Or can i use something like this? https://www.ebay.co.uk/itm/395524214497?_trkparms=amclksrc%3DITM%26aid%3D1110018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26asc%3D281023%2C280568%2C280618%26meid%3D4018390c9ba246f794ed58b8b19ec80a%26pid%3D101430%26rk%3D4%26rkt%3D12%26sd%3D205160403603%26itm%3D395524214497%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DCompVIDesktopATF2V2AndXaiHotClickWithCompV6WithEbertNRTRecall%26brand%3DUnbranded&_trksid=p2332490.c101430.m2460&itmprp=cksum%3A3955242144974018390c9ba246f794ed58b8b19ec80a|enc%3AAQAKAAABMDJfxvEKz%2FWsdyy97PIVwAhtkTIJPGKp%2Bu7TYjjsvNO4eN9duTRR%2FSVFYts6UXmN8tSK75ee0LypjLaKkPNQ2gkat4DyNLnViXKBVpI1%2B5fAYfWiGJa5QlqEPseqbSJUD9gVo2KSXbnmQjuPDJH4flTH2bOLSO%2FvMrLjgPDIc7vGrlKtoSauZb0q%2Fu43zLR0J8tg1z5dPMV%2FcHtnqRYXb7R7V8G%2FrQGhpY1sWtGJXc4TWc78ccs69UXnMiCqqd05ITd%2BY7Vwbq5Uzd%2FWhmiZCytO66vqDnbJn03qN%2Bin0ImF5sgbgu9uD45tXNN8cr4IWfqzIEEpaKcgqilwbTDxMkIQ4sGcgz7IhYONV017vE6P9ksZ7n%2FFVwgs3kAfMb0%2FLGjwaqhwo0yilTIjGHg9mwU%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01JMR0X9WMB8DPEX82P2P3CRXN
    • I would be lying if I said I wasn't interested in what MCM were going to do with the NC I really enjoy their banter and occasional collaborations (like Alan from TSF, Ben from BCW, or any of the Haltech guys throwing around their experience), and I have probably watched everything they have put out
    • Not yet, we basically drove it to a private road, got the logs and drove it straight back. I think I need a new passenger seat belt after the mrs squeezed the life out of it.
    • Sounds insane! 🤤🤤🤤  Do you have any vids of it driving?  A flyby would be nice!
