Hello all,
I am new to SAU and I currently have a R33 GTST 4speed auto. I currently have a 3" HKS exhaust system and a k&n air pod, but besides that it is stock standard.
I would love some suggestions on initial mods to get a bit more out of the car. I don't want to spend tens of thousands, but I am prepared to spend a little on some light mods.
I have a friend who mentioned that obtaining and installing a front mount intercooler and a boost controller is all I would have to do to push the car to about 150-200kw without too much hassle.
Is there anything else I should consider before getting any of these components (ie. ecu, bov, etc.)? Any other easy mods that wont cost the earth that I should look at?
Are there any particular brands/models you guys would consider as good value for money without taking out a home loan? I dont want to do a 10sec quarter just yet.....maybe one day.
Thanks all, your opinions are greatly appreciated.
BOOMAU.
https://www.sau.com.au/forums/topic/62924-open-to-suggestions/
BOOMAU
I'd start by getting your current engine checked out - get a compression / leak down test done FIRST. Maybe even a power run on a dyno (should only cost you $120 or so)
That way you will have a better idea of the health of your bottom end, and the engine in general.
Then start to tweak things up.
just one mans opinion :P
doesn't matter what you do to your car it is never quick enough. I only installed a whole heap of parts about 3 weeks ago, already I am looking for a bigger turbo. all I am saying is be prepared you will spend alot of money on your car. I can't be helped.
Yeah I realise that, but I am trying to resist the temptation to spend a small fortune on my car.
I would like some ideas on a good starting point to build from, something that can get my car running a bit quicker than standard.
What do you guys think of installing an APEXI AVC-R with a front mount intercooler say a Blitz, and a blow off valve (open to suggestion on a brand)?
I think that I am going to leave my turbo standard at this stage, please correct me if I am wrong but can standard turbo handle up to about 12psi without too much trouble?
Please don't flame me for sounding like an idiot if this makes no sense or sounds stupid. Would like some suggestions.
Thanks
BOOMAU
avcr is a waste of money. hks evc or blitz ebc for about 1/2 the price of the avcr
or even a $100 bleed value, but the bleed valve will spike. i got my hks evc 3 for $250 and its perfect. set boost to 0.75 bar and its an ebc so it doesnt spike. boost controller is set and forget screw the cool looking screen thingy on the dash (avcr unit)
intercooler just take it to a local workshop and say supply and fit one, brand is pointless its just metal. you should be able to get a good core supplied and fitted with piping for $1300 whereas a blitz kit will be 1400 not fitted
blow off valve will add no power and give you defect points and stall problems if not adjusted properly stock bov is fine
run about 10/11psi through the stock turbo no more
check out an ecu remap or aftermarket ecu (powerfc comes to mind)
remap for about $300 or powerfc for $1000
also looking into a good set of tyres and cold air intake kit
as ive just read its auto so look at apexi safc + remapped ecu at the worst case
cant get powerfc as its auto so a remap and apexi safc will probably give you best bang for buck
200rwkw shouldnt be too hard to get to
ive got
powerfc
5 speed manual (not auto sorry so not a good comparison)
fmic (some hybrid brand no idea)
3" exhaust system from turbo back with new hiflow cat
hks evc3 running 0.75 bar
pod in engine bay (bad idea should be cold air feed)
255 tyres on the rear help traction
gets tuned tomorrow should get 200rwkw hopefully
    • Nah, new members can't post pics until they reach a certain post count. If I get a chance I'll promote you to full member, if @Prank or someone else doesn't get there first.
    • Drilled the rubber out on a slow speed and it didn't catch much at all. Probably only half a dozen holes was enough to shred the rubber and it dropped off easily leaving the inner sleeve behind. Will tackle that later
    • I havent bought a manual cover for the dash yet and no cluster change, won't bother me too much, I just need to get that auto box gone, manual in! I miss my manual. 🤪. We started last weekend and managed to get the box out. Planning to start putting it in this weekend and then order a single piece tail. We were super careful to take time and not damage anything. It's my first time working under the car.  With my S15 mainly worked in the bay. This time, it was a headache because of three or four bolts only. They simply didnt want to leave thei homr and the one securing the tailshaft, another above the GB, and the one securing the lipstick was a shit. Mates mate, Davo caught fire 🤣, nearly opened his chest up with a grinder 🤦🏽‍♂️ and both mates nearly had a plate from the box land and slit their head open. Fun times. We all survived. Not the easiest working with limited access on jackstands. As I'm sure we can agree these are the memories which make us love our car. For all three of us, was an awesome weekend and Sunday 3.30am before tools down was a fantastic effort. I need to upload pics, but looks like it needs to be via Url now. We used to be able to just upload pics back in the day. It's been that long! 🤪 Im currently spraying rustoleum under body, not because it's rusted. It's super clean, but just so it's protected for the next 10 years. There was a few surface rust spots. Which pretty much wiped off with a 3M scourer.  Really impressed with how well the previous owner maintained it. Bank account went down so quick! Service, then GB - managed to get a spanking new 34 genuine box from Nissan. All the rest of the conversion parts from Kudos.  Went with a Nismo short shifter. New pedals and Exedy Clutch and FW. Ordered the Prp Rear Main Retainer kit which should arrive Friday and my first engine mod part just like I did with my S15 will be the Tomei Expreme Turbo Outlet. Already on order. It'll likely sleep next to me on a pillow during the coming months. 🥰 Last build was on my JET200GT profile and on SAU and Hardtuned I had documented the build. Planning to try to do that again. Brands feel scarce now. Wish we still had ARC and Apexi parts readily available. Exhaust - need some advice on this. I had an Apexi exhaust on the S15 and loved the tone. My mate had a HKS HP Silent on his 33 and suggested I go with that to avoid drone. I can't remember hearing an RB25DET running that so will likely need to wait for a meet or something to hear it.  Not after big power, just enjoy building it, and drivability with minimal negative attention.
    • Have a chat with Ben at Moore Performance or Jesse at JS Performance.
    • Thanks both. All good advice. Reminds me of drilling through stone wall for drainage pipe 😬 I'll let you know how I get on if I still have use of my hands afterwards 😅
