Can you post a photo?
Here's a few ways to tell the difference:
R34N1's are ball bearing (see if it spins easy)
R34N1's have 9 blades on the turbine compared to 11 for the R33
R34N1's compressor housing does NOT have the A/R marked on it
R34N1's have a divider between the wastegate and turbine
You should be able to work it out from that.
Cheers,
Gary.
Guest Mashrock
Gees, thanks for the info. Guess they're not 34s cause A/R is marked and plus there is no divider for wastegate gases...but they sure as hell spin easily. They're actualy meant toi be NISMO N1s. Could these be BB?
all n1's are bb, i beleive.
quick queation how much u pick them up for?
and are you doing cams also. this would be rather advised.
Just a note on this i just recently picked up two brand new R34 N1 turbos for my GTR so new they had not even been removed from the nissan box and wrapping.
the only cost me $3000 for the two, and thats to my door. i know a guy who sells them for about $2800 for the pair brand new :bananaman
Guest Mashrock
with n1 actuators?
is that how its spelt??
with n1 actuators?
yep with n1 actuaters well there direct from nissan so what ever ones they fit on them there nice and small compared to all the other turbos i have bought in the past for my other cars.
My bro got them from Banzai motorsports for ~$2500 I think (ANTS?).
Cams... what size do you recommend? Its true that the GTR has piss small cams standard (unlike the FJ20). Personally, I think a GT3540 plus a set of 272s would be nice!
Dude, turbs cost me $1,900 from Banzai.
Yes, I agree GT3540 would be nice. Pls buy me one.
Seb, I also got a new exhaust manifold gasket today from Hi Octane Racing.
Now filing for bankruptcy. :P
OohArrGtr
check the serial number (from above post) - if they are R34s - then they should be good for 600+ hp on your GTR.
I have just had a pair fitted - waiting to run in the new bottom end.
BTW - nismo.com.au list them as 320hp and are selling the pair for $4K + I think
    • The nissan manual says to change coolant every 2 years. Is this still necessary if you're using coolant like Penrite or nulon which has improved over the years? It says it lasts 500,000km which seems hard to believe lol.
    • According to the Muse website, totally different material. The originals were that horrible solid foam rubber that was used for a lot of rear spoiler/flap things, like on Mitsu Galan GSRs. Heavy, and with enough compressibility/flex that any paint on them would crack fairly quickly. The Muse ones are just ABS, which is obviously similar to GTR lower front lip, etc etc. ABS is a good choice if you have the ability to tool up for it. The only thing better might be TPU-RIM or something equivalent. The TPUs were good. Plenty of flexibility (in twisting, bending, etc) but not really in compression.
    • Update 24/01/2025:    Bought a GReddy/Trust Intercooler (crossflow spec-LS) that was meant for a R33 GTST $871 AUD shipped, and a GReddy Profec boost controller $483 AUD, both brand new from Japan. Being honest, I would've thought the intercooler kit was discontinued but I guess not yet. Decided due to funds + time, I'll stick with a nistune on this stock-ish setup ( stock turbo set to probably 10-12psi ) and have it run cleaner ( suspect the 3" turbo back etc has sh*tted on my economy ) for my trip down south soon for the WSBK. Hopefully I can get it all installed and tuned by then. As for who I am getting it tuned with, I will be going with Toshi, (not hearing back from DVS so scratch that). There is also Birrong Auto but not sure if they do nistune installations and if they even tune it... Otherwise, anyone know where I can get my hands on an aluminium intake/suction pipe for an RB25DET NEO?
    • The german cars I've worked on seem to have that issue(in more than just headlights). Mostly where hot, but also just the insulation hardening and cracking in various places. Not abnormal from what ive seen.
    • According to the Muse website, similar material, but not the same. Meant to help with stopping the paint cracking. In saying that, I had genuine ones on my last grt, and never had that problem.   Could you post pics when you get them? Very much thinking of buying the Muse ones over fibreglass.
