my mate just bought a 96 gts (rb25de), i told him he's an idiot coz cud have gotten a gtst for an extra grand but he says he wants a full house gtr engine lol, so what are the specs of this engine? i know it makes around 130 - 147 kw
anyone know the stock 60ft and 1/4 mile times??
He shud race my gtst makes around 210rwkw which is ok considering havent spent more than 5 grand on the car.
So yeah how does it compare in the 60ft and 1/4 mile times? Anyone have some actual figures?
https://www.sau.com.au/forums/topic/62956-rb25de-specs/
ok mate, firstly a gtst makes about 184KW stock :P
stats on the RB25DE:
RB25DE
Bore & Stroke
Capacity
Power
Compression
Twin cam
86 X 71.7
2498
190ps @5600
23.5kg's @4800
10 to 1
The RB25DE is the middlebrother of the nissan RB series Its a Twin cam 2.5 liter.
This engine is very torquey and is great if you don't require turbo performance.
It features in the R23 R33 R34 series of Skylines both 4 door and 2 door and came in manual or automatic.
also is came in the R33 & R34 gts-4 so that the gtr had no competion.
don't quote me on 1/4 mile times, but I think it's about a second slower over the distance than a gtsts (both stock)
The RB25DE has some go - nice form a running start about 50k's and dropping back a gear...but it's never going to beat a 'worked' gtst - without spending money on it....allot of money :P
Some easy shit he can do:
Work on intake - high flow filter/POD filter
2.5" Exhaust (cat back or full system - just no larger then 2.5")
Extracters (check link in my sig for some cheap!)
NOS (he can get a nice wet kit for <900 bucks and run a 50HP shot)
Simply stuff ^^^
Then ofcourse he could spend 3500 bucks, buy a frontcut 33 and do a conversion - but if it's his first car - the relative savings on fuel/services/insurance/running costs will be great - they look nice and go ok - i'v beaten every homo VL driver whom tries to go 'fully sick' on the freeway - lol - also the older silvia's/180's have no chance....
https://www.sau.com.au/forums/topic/62956-rb25de-specs/#findComment-1185498
your mate is not an idiot for buying an NA, and I would like to think that he knows what
he is doing.
Everyone always says forced induction is the way to go, of course for an extra grand or two
you definately get bang for buck... so why not.
I paid as much for my GTS as the cost of a GTST, for a COMPLETELY stock, clean, first owner,
etc car.
It comes down to your needs, and driving lifestyle. If your not racing, then why do you need
turbo? For a street driven car, for daily use - I find NA is the go.
Your mate might have his own reasons for buying an NA. Whether it be insurance, or
fuel consumption, whatever...
That said... gatty has pretty much summed up what can be done to NA engines.
I think the factory quoted figure is 147kw@4400RPM, I have recently put my car
on the dyno for a base figure, stock except for pod filter... I managed 108rwkw
https://www.sau.com.au/forums/topic/62956-rb25de-specs/#findComment-1185575
Stock times are a bit hard to answer as alot depends on the driver and the strip in question specially when it comes to 60ft times. There are so many variables that come into play, I've seen a stock auto sedan 96 GTS25 do 16.8 and a stock 94 GTS25 coupe do 15.8 so if you say somewhere in the middle you should be about right. With a good driver you should get around 2.3 sec 60ft.
Hope thats of some help
https://www.sau.com.au/forums/topic/62956-rb25de-specs/#findComment-1185666
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
