1996 Series 2 R33 M-spec25t
Dyno at 218rwkw by Hitman
Kilometres 90000
Body 2 door Coupe
Colour white
Transmission 5 speed Manual
Engine 6 cylinder Petrol Turbo 2.5L
-Fujitsubo Legalis R typeEVOLUTION Turbo back
-ARC Super Induction Box
-HKS Super SQV
-HKS Turbo Timer
-Apexi AVC-R
-Apexi S-AFC II
-NISMO GT shift knob
-NISMO 300K Speedo
-NISMO Carbon pillar garnish
-NISMO Carbon rear wing end plates
-NISMO Radiator cap
-NISMO 17" LM GT2 Racing wheel
-NISMO Adjustable Suspension Kit
-NISMO Front strut brace
-GTR Rear strut brace
-Spilitfire boost guage
-Pioneer DEH-P3550MP CD/MP3 Player
-Brant Alarm System
-Genuine GTR rear wing
-88House 6000K HID Kit(Made in Japan)
*Original airbox and BOV will go with the car
Car been very well looked after
I want to swap a DC2 Type R (Sydney)
Reason: want a smaller car for daily drive
PM me if interest! or mail me at [email protected]
https://www.sau.com.au/forums/topic/62960-218kw-r33-series2-swap-dc2-type-r/
Nice car :P Looks very clean and straight. One question, 218rwkw? Correct me if i'm wrong but I don't see any mechanical mods listed, from the looks of it, the engine bay looks stock and you've still got stock cooler. Just seems like a lot of power for air flow (arc box + zorst)fuel + boost.
how much you after for the car?
Please read my first post.. I want to SWAP DC2 Type R instead of money... I believe some Type R driver out there want to change their car to a more power car like SKYLINE(100kw more @ wheel)....
ahaha r33 more powerful then a dc2 ahaha! dude dont make comments about cars if u have no idea the type r is more than able to keep up with an r33
Ummm i'm not trying to make any comments about any car here... i know what DC2 can do and i know how good it is... and please note... I was saying (((power))) in kw @ wheel .... if ur DC2 can keep up R33 on highway.. then good for u... and if ur post got nothing to do with the swap... then go post somewhere else... Thank you
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
