hi guys
about a week ago my 33 started clicking from the right hand door ,
so i pulled the trim off and found that it was comming from the white box that has something to do with the electric windows,
now the strangest thing is that it will click every 10 seconds twice .with every click the engine revs up and down ,not much but enough to notice it (say like when the aircon is turned on)
does anyone know what this little white box does in the door
and how it could be afecttting my revs
https://www.sau.com.au/forums/topic/62969-up-and-down-revs/
hi guys
I have no idea why it is clicking but it will be switching the electric window motor on and as the window is up (or down) it is pulling about 10amps and loading up the alternator, causing the revs to fluctuate slightly.
Try tapping the passenger window up switch with the window already closed and it should have the same effect.
As for fixing it, maybe have a look for a short in the wiring, or swap the unit.
https://www.sau.com.au/forums/topic/62969-up-and-down-revs/#findComment-1185811
thanks for the reply bhdave
i pulled apart the electric button unit .and found that it ha s a crack on the bottom of the up and down switch ,which since has broken (due to my clumseness) and has made it stay on the up position,so it looks like ill be lookin for a new unit this weekend
thanks for the info
https://www.sau.com.au/forums/topic/62969-up-and-down-revs/#findComment-1188413
  • 2 months later...
Hey my door motor started doing exactly this about 3-4 days ago. It doesn't happen all the time but i'd say a good 50% of the time the car is on, weird! Another problem i've been having is sometimes the up/down button doesn't work so I just open/close the door and it works fine, probably related no doubt.
I'll pull apart my door trim tomorrow and see if their is anything obvious wrong otherwise it's off to the Auto Electrician for a 2nd look at it.
If anyone has a perfect working driver-side motor for sale pls PM me.
https://www.sau.com.au/forums/topic/62969-up-and-down-revs/#findComment-1278836
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
