New Cabramatta Meetup Cruise Date!!! 7/12/02
  • Replies 312
Alright the 7th it is then homos!!! around 11:am
Big or small I am still going!
Gotta buy some cheap ass sausages and cups and plates.
you dirty ****s bring food too.
We will have videos and photos and just have a ****en good time!!!!
The more the merrier!!!!!!!!
LETS MAKE THIS THE BEST EVER CRUISE SO.........
I NEED YOU GUYS TO BE THERE!
Originally posted by GTR-80Y
Oh, and Cumberland maccas this sat night doods for runs or just gay sex.
i hope this is at the cruise aswell :D
hrmmmmmm ill definately be there.... and ill kick start it off..
anytakers ??
not all at once guys :D
(ohhhh must be male)
the 7th?? hmm gotta check
man, have some sort of xmas party for either work, bball, soccer or uni, i dont know which one, im soooo lost :D :eek: :confused:
So hectic this month with the xmas parties and shit
But if nothing is on, im in :D
Where we headed Minh ?
Originally posted by [MRTRBO]
F@rk im working from 2:30 till 9:30 pm !!!!!! :)
I might catch up with you guys if yous go crusing at night ????
Why catn it be a Sunday cruise to tha gong ?
i thought Sundays went off at the gong?
But have fun either way :)
They do go off SUNDAYS!!!!!!!!!
CIHAN will organise a sunday gong cruize- see if i can organise some other car clubs to come down too
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
