Hi all,
Next problem...came back from a short drive, no issues whatsoever.
Go to select reverse to go for a drive...and I could not select at all. So pushed the car out...and the rest of the box is perfect.
Could it be the reverse shift fork perhaps?
The box has been no problems apart from a very slight notchiness for 3/4th change...
Obviously the box has to come out to check the fork?
:P
https://www.sau.com.au/forums/topic/62974-no-reverse-r32-gtr/
Doesn't reverse share the fork with 5th? does 5th work?
Does it just physically not go into gear? or do its go into gear but just act like its in neutral?
Ferni,
It wont go in at all. So physically it wont allow me to select reverse...
The manual shows a shared OD and Reverse fork rod, but also a dedicated reverse shift fork...
:headspin:
On the R31's, I think the reverse gear has no synchros so sometimes it just wont go into reverse. If you let the clutch out (in neutral) then in again it will then just slot straight in. Try pumping the clutch then trying again. It might be the same on the GT-R box. Worth a try anyhow.
Question is....can you still get 5th ?? Also does the shift lever still have normal travel when trying to get reverse ??...or does it stop part way ??
5th is 'operated' by a 'pin' link mounted on the reverse shift fork. If you can get 5th, then it's not a linkage problem, but probably a broken/damaged reverse shift fork or roll pin. If you can't get 5th it could be a linkage problem further forward in the 'box, but could also still be something to do with reverse mechanism. There are other remote possibilities like shaft circlips breaking.
Thanks Steve. I can get 5th. I guess trying to fix this issue would be cheaper than getting another second hand box.
Could be a spring and ball issue locking me out of reverse perhaps?
You could have a look at the reverse check device which is mounted on the passenger side of the O/D case just below the pressed steel cover plate. It's held in by a 10mm head bolt and is sort of 'tear drop' in shape. It's got a 'cam' and hairspring arrangement and I suppose there's a remote possibility the spring could break. But if you've got normal lever travel when trying to select reverse it's unlikely to be that. Anyway, you could try taking it out and seeing if it makes any difference (note it's got a sealing o-ring on the body so might take a bit of levering, plus I'm not sure there's enough clearance to remove it completely with the gb in the car).
There's also a check ball, spring and plug for the O/D and reverse mechanism on the drivers side of the gearbox on the sandwich plate. Again, you could try taking out the plug and see if it makes any difference.
  • 7 months later...
Guest DIRTgarage
I've heard of the spring going...did you work it out?
Was there an easy way to fix it?
we had a reverse problem.....it was the reverse thrust washer in the rear half of the box....it stopped us selecting it at all....it was in a second hand box we borrowed when we smashed on at Eastern Creek earlier this year.
also check your hydraulics. much cheaper than pulling out the box and it's possible that a dud slave or master is preventing you from completely disengaging the clutch, hence you are unable to select reverse. easiest way to test this is to switch off the engine, then try and select reverse.
  • 4 months later...
*bump*
Hi team.
Same problem here. Gearbox oil is 1,000km old. Reverse no worky. Difficult to engage 5th when engine is off and without the clutch. 1st through 4th engage engine off no clutch.
Reverse does not engage at any time. It does not move on the fork at all. The wasn't any crunch/bang nor any whining in the gearbox prior to failure.
Thanks Steve and Paul for the info! It gives me something to go on.
Here's hoping I can sort this out in the garage... it crumped whilst taking my wife out for our wedding anniversary! :P Sure puts the pressure on at the shops when you only have one shot to nail the parking space. :)
@R32zilla: Mate did you sort this out in the end?
Edited by cowie165
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
