Im in the middle of trying to replace my tie rods on my R33, ive got the steering rack out of the car so i can work on a bench. I have removed both steering rack boots and am now trying to remove both tie rods.
There appears to be four tabs to each side of the steering rack locking eack tie rod in to the rack. Ive used a flat punch to knock up the four tabs on each side of the tie rods however there seems to be something preventing me from removing the tie rods, anyone change there own before?
Any help would be great as i would like to get the car back on the road asap. cheers
https://www.sau.com.au/forums/topic/62979-replacing-tie-rods/
The tie-rods are the outer parts of the steering system, and should be able to be removed without removing the rack from the car.
If you are trying to remove the rod (it doesn't seem to have a name, according to the [R32 GTR] manual - maybe its the "inner socket"), it seems it simply screws in and out.
Im not trying to just remove the tie rod ends from the hub, im wanting to replace the whole tie rod and the tie rod end from the steering rack. My LH tie rod is bent i did it out at calder last weak, some people call them different things that is just the name i am used to. What i want to do is get my car back on the road without having to replace the whole steering rack and even upgrade at the same time to some stronger tie rods and ones that give me a little more lock to lock steering. Apparently some brands can give an extra 3 to 4% extra lock at full lock.
Anyways so i spoke to someone last night who was able tell me how the did theres on an s13, So once you have used a punch and hammer to tap up the lock tabs you then get a shifter and place it around the tie rod side of the tabs and just undo, if the rack is moving around to much to undo use another shifter on the rack side to hold it in place. It was so easy once i knew there was a thread and it was just a matter of untwisting.
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
