Replacing tie rods?
Im in the middle of trying to replace my tie rods on my R33, ive got the steering rack out of the car so i can work on a bench. I have removed both steering rack boots and am now trying to remove both tie rods.
There appears to be four tabs to each side of the steering rack locking eack tie rod in to the rack. Ive used a flat punch to knock up the four tabs on each side of the tie rods however there seems to be something preventing me from removing the tie rods, anyone change there own before?
Any help would be great as i would like to get the car back on the road asap. cheers
The tie-rods are the outer parts of the steering system, and should be able to be removed without removing the rack from the car.
If you are trying to remove the rod (it doesn't seem to have a name, according to the [R32 GTR] manual - maybe its the "inner socket"), it seems it simply screws in and out.
Im not trying to just remove the tie rod ends from the hub, im wanting to replace the whole tie rod and the tie rod end from the steering rack. My LH tie rod is bent i did it out at calder last weak, some people call them different things that is just the name i am used to. What i want to do is get my car back on the road without having to replace the whole steering rack and even upgrade at the same time to some stronger tie rods and ones that give me a little more lock to lock steering. Apparently some brands can give an extra 3 to 4% extra lock at full lock.
Anyways so i spoke to someone last night who was able tell me how the did theres on an s13, So once you have used a punch and hammer to tap up the lock tabs you then get a shifter and place it around the tie rod side of the tabs and just undo, if the rack is moving around to much to undo use another shifter on the rack side to hold it in place. It was so easy once i knew there was a thread and it was just a matter of untwisting.
 Share
    • Hi fellow SAU members, I want to put coupe tail lights on my R32 sedan. I have been told it was as easy as changing the boot lid and the tail lights and possibly the rear bar. I have since found out that this is incorrect after buying the lights and boot. The coupe boot dosnt allow the boot to oprn on a sedan and the tail lights won't fit either. Has anyone done this or seen it done and could help me out with some guidance or instructions to get it done.
    • Noice one 👍 I've done a 1:16.300 at Watkins Glen, will keep at it. Still have to knock off half a second at Suzuka in the Roadster
    • Two golds! Struggled to get silver on Gran Valley.
    • Interesting that it has 2 to the USB stick. Are the ones to the USB stick different? Or labelled anything at all? Telstra 4G is Band 28 is the long range one you want, it's 700mHz. I'm trying to do some reading on the Cel-Fi stuff, but I can't find any decent info online that makes me feel comfortable being able to work out the sort of antennas we could get away to swapping it over to. The antennas I'm starting to do some stuff with at work, are a transparent antenna. They're designed to stick onto the window. Which means you wouldn't even have the antenna outside the car. Volkswagen have just started using the exact same types of antennas on some of their new cars (And from the same antenna manufacturer). But, RF stuff is a bit of a dark art some days, and getting it wrong in your car could make for a terrible waste of money trying to swap antennas :S
    • I'm not going to lie Duncan, Saturday and Sunday were pretty rough days. The sort of work I was doing would previously have ended up with me spending about an hour and a half chatting with Neil. Firstly about something I had a question about, and then both of us rambling off on tangents.  I think how Neil did things, and his attitude to getting it done is helping me in part to get this stuff done. Then I can actually do the things I enjoy more easily
