aww :D is the DezertEagle on that forum the same that use to be on here? His sig said he sold his line! Bummer... all cause of a stupid defect :D
Hey dude, yeah it's sold. New owner drove away with it today. Hope your car is going good mate, very similar set ups aye!
Will be getting something more sedate in the meantime, looking towards an R34 GTR after I'm 25 though :wassup:
there were a couple of nice skylines on that cruise in particular
One Red R34 Was hot as IT had such a lumpy sound to it The twin turbo setup on it was awesome high mount turbos and about the size of GT3037's (as advised by friend) but it sounded so sweet.
and also White 34 with black bonnet and the plate IYI was also there.
The cops only blocked Terrigal because there were too many cars in there.
Another example of what happens when a poorly organised cruise results in hundreds of cars suddenly appearing at what is normally a familly area on a Sunday afternoon. Police go into damage control when such a huge number of cars show up without any prior warning
The clowns behind this have run such an event before, with the similar results yet they seem surprised at what happened this time?
:D
That RED R34 GTR is apparently a monster. Supposed to have HUGE power and sounds insane. Has either Twin 3040's or 3037's and a 2.8L bottom end.
And yes, I agree. poorly organised cruise with plenty of idiots. But what more do you expect from Hot4s?
The pics i saw of it, there was insane amount of cars there, a whole carpark as big as 300 spaces was full, in the pics saw some beatiful skylines, such as CYIFLY and that Red 34 as well as another skyline cant remember, god bless you skyline lovers :Bang:
I own a SR20DET silvia but hehehe, but your all great people!!
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
