PRICES REDUCED
1. R33 GTR Factory Intercooler - Good condition $450
2. R33 GTR Factory Fuel Pump - Good Condition - $180
3. R33 GTR Factory Front Adjustable Strut Brace - $180
4. Nismo black leather gearknob - good condition - $45
5. Used Greddy oil cap - blue - $60 SOLD
6. Used Greddy radiator cap - $40 SOLD
All parts located in Sydney
Post or pm for more information.
Nick
hows the fuel pump? condition ? i located in mel.. do u send here?
Fuel pump is in perfect condition - still in use in car however it is being removed due to a requirement for a larger pump to cover modifications I am about to perform.
Postage to Melbourne is no problem
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
    • Front seats now in, fixing a little rust then front doors sealed up again finished. had to install a fire extinguisher within arms distance of drivers seat for hill climb regulations. little bit of good old silo diff action lol IMG_9146.mov
