got my cars dyno figures 2day!?!?
TRY032
 Share
I had my car dynoed today at rev zone in nunawading... my car is a stock as a rock 1989 r32 gts-t and i pulled 103.5 @ the rear wheels........
Does this sound correct from a 158kw @ the engine car??
taking age and elcetronics, air con etc. into consideration
What rpm was the 108rwkw made at? Also what was your tourqe figure and at what rpm? I pulled 119rwkw with a 3"cat back, pod, thermo fan, no aircon. I was a bit dissapointed but I guess I wanted to much! The thing pulls great though!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
yeah, im kainda disappointed, i had changed oil and fulel filter, engine oil, spark plugs, to brand new iridiums bout 20 mins before... had that mobil 8000 shit which i find better than optimax and was hopin for about 110@ wheels my second run was worse, only made 99.7kw @ wheels..
they said full exhaust (dump, front pipe, hi-flo cat etc.) and boosted will make guaranteed 150 at wheels?????
That would seem about right actually, a guy at my work has the R32 Silvertop in his HR31 coupe, it is completely standard including airbox and all. The only thing it has is a bleed valve set at 10psi and it made 127rwkw so your figure on stock boost seems about right.
10psi is stock on silvertops anyways i thought
i picked up 20kw at rears from a turbo dump back 3inch hiflow exhaust ..mind u my ole school ECCS redtop 20det only made 96rwkw bog stock as a rock with auto .....
Matt
I made 149rwkw's with full 3" exhaust from turbo back, 11PSI and a hot air pod! Exhaust would have to be one of the best early upgrade mods u can do!
what is essentially the difference between stainless exhausts and mild steel... i can only see one which is on has a bling factor, and also gives the node a bit more of a metalic sound to it... and doesn't expand as much as parsay... and the other is just mild steel... dunno
exactly what u said, oh and also doesn't rust, i'd just go mild steel!
 Share
    • Hi fellow SAU members, I want to put coupe tail lights on my R32 sedan. I have been told it was as easy as changing the boot lid and the tail lights and possibly the rear bar. I have since found out that this is incorrect after buying the lights and boot. The coupe boot dosnt allow the boot to oprn on a sedan and the tail lights won't fit either. Has anyone done this or seen it done and could help me out with some guidance or instructions to get it done.
    • Noice one 👍 I've done a 1:16.300 at Watkins Glen, will keep at it. Still have to knock off half a second at Suzuka in the Roadster
    • Two golds! Struggled to get silver on Gran Valley.
    • Interesting that it has 2 to the USB stick. Are the ones to the USB stick different? Or labelled anything at all? Telstra 4G is Band 28 is the long range one you want, it's 700mHz. I'm trying to do some reading on the Cel-Fi stuff, but I can't find any decent info online that makes me feel comfortable being able to work out the sort of antennas we could get away to swapping it over to. The antennas I'm starting to do some stuff with at work, are a transparent antenna. They're designed to stick onto the window. Which means you wouldn't even have the antenna outside the car. Volkswagen have just started using the exact same types of antennas on some of their new cars (And from the same antenna manufacturer). But, RF stuff is a bit of a dark art some days, and getting it wrong in your car could make for a terrible waste of money trying to swap antennas :S
    • I'm not going to lie Duncan, Saturday and Sunday were pretty rough days. The sort of work I was doing would previously have ended up with me spending about an hour and a half chatting with Neil. Firstly about something I had a question about, and then both of us rambling off on tangents.  I think how Neil did things, and his attitude to getting it done is helping me in part to get this stuff done. Then I can actually do the things I enjoy more easily
