hi guys thanks for your help with my gearbox. I changed the oil and its 100%better not as much heat, no noise and smooth changes ( :
One thing that might help is that i sythened the oil in by running a pipe into the gearbox and poured the oil in the other side instead of using a pump to pump the oil in. I found this very easy
Once again thanks heaps guys ( :
  • Replies 84
i changed my geaarbox oil on the weekend because it was crunching going into 4th at full load. put castrol vmx80, nulon addative and found about a litre of lightwieght redline oil so put that in there too.
didn't see a change staight away, but after about 200k's of driving the problem went away. now i can change into 4th at redline.
is it safe to mix oils???
Hi all.. I reckon this cold gearbox problem must be a skyline thing 'cause mine from 1st to 2nd on a cold morning is not very nice. As someone mentioned before, double clutching helps but after about 5-10mins driving around it's all sweet.
Not long ago I put Royal Purple max gear in both the gearbox and diff. It did improve my gearbox on the cold starts as it now takes less time to become smooth.. and when it is smooth it's much better than it used to be :(
Gizmo73 also used Royal Purple and he reckons it also improved his gearbox over the Redline Shockproof.
its bad to mix synthetic and mineral oils in your gearbox.
Ive been told that once you run synthetic, if you run mineral oil after, you will ruin the gear system. If you read up and do a search on it, you will understand. The synthetic oil beds into the gears, and then running mineral oil will eat away at the gears. Have a read of it, because im not 100% what it was exactly
hi guys my car produces alot of heat from under the gear stick. Do you think this is the gearbox or the exhast or sumthing? It gets quite hot after driving a while. Could it be that my trans oil is low? Any suggestions will help thank you
Mine gets hot but haven't noticed any mechanical problems well not so far anyway
why would you use mineral???
use the synthetic stuff
if you mix 50/50 mineral and syththetic in your gearbox might not be good idea.
However if you drain all the oil out of the gearbox and refill it with either sythetic or mineral you should have no issues with oil mixing together
BUT STICK WITH SYTHETIC BETTER PROPERTIES AND LONGER LASTING
cheers
  • 8 months later...
Hey i dont know if i done it correct or not.......umm, i used the fill plug, which was on the passenger side of my car to drain the oil.....i then dropped the jack down, open the bonnet, took off the dip stick, and used a funnel to fill the trans fluid into my car (auto's have the dip stick).....is this correct???as i didnt see a drain + fill plug, only the fill plug on the bottom( i guess the fill/drain are the same in autos....as its there to just drain then?)
  • 4 months later...
Nope, definately didn't drop the oil (not that silly) just checked if I could loosen them both first, was only able to get the drain plug.
PT, yep, it's manual, but what's involved in pulling out the shifter? Just unscrew the 4 screws, lift the plate/cover then fill? (measuring the quantities of course)
I'm against filling through the shifter due to the extra difficulty in measuring the amount going in and the risk of getting that stinking crap in the interior. Get a breaker bar on to the filler plug, mine was tight as a... well it was very tight and a breaker bar was needed to get it off. I then used a $10 pump bottle from supercheap to get the oil in. I also did a write up of this process if you need further info.
Cheers
nissan reckon vmx-80, i hated the shit it was too thin
im using the thickest shit available @ repco in my rb30 box, kinda shit to drive when cold, but i used the nulon manual box treatment aswell
i fill thru the shifter, just use a funnel and measure it before you tip it in
Edited by Rednisr31
Not sure what the 33 box is like but on the 32 box the reversing switch is the same height as the fill plug. I couldn't get my fill plug undone so I took the reversing switch out and used that hole to fill it instead :D
ActionDan, beleive me, I've tried to get the bloody thing out but it just won't budge!!! Measuring the quantity of oil would be easy as would using a funnel to pour it into the shifter so it looks like it's the best bet for me at the moment
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
