G'day all,
Just did a gearbox oil change on my R33 GTS-t and I thought I'd share it with everyone.
My box was crunching into second gear for the first 4-5 changes first thing in the morning (it get really cold here), so I thought that the synco's in second were stuffed. As well as that there was a whining coming from the gearbox for the first 2-3 minutes of driving in the morning.
I changed the oil and what a difference !!!!!!
Cold gear changes are sweet now, and no whine for the first few minutes of driving.
I used Castrol VMX80 gearbox oil, the difference is great, smoother gear changes, and when normal (warm) driving the car seems quieter than before, even though I didn't think it was noisey before.
To do it is easy.
Do the following after a drive so the oil is hot (and will flow out better).
Use a trolley jack and jack up the drivers side of the car.
Use axle stands under the chassey to make it safe.
You'll see the drain plug on the gear box about 1/4 way from the back of the box. A 1/2 inch rachet fit's nicely into it. You'll also see the fill plug on the drivers side and it's the same size as the drain plug.
Make sure you loosen the fill plug before you drain the oil. You don't want to find out that you can't get the fill plug out after you've drained all your oil!!!!
Drain the oil. Put the drain plug back in and then remove the fill plug. I used a pump to get the oil into the fill plug as it's a tight fit.
The gearbox took close to 4lt of oil. Basically you fill the gearbox until oil comes out the fill hole. Make sure you have the car as close to level when you fill it. I know it hard if you have to jack one side of the car up.
Put the fill plug back in. Lower the car, and that's it.
Easy, and has fixed all my worries.
BTW: the VMX80 was about $29, and the little oil pump thing was $12.
J
https://www.sau.com.au/forums/topic/631-gearbox-oil-change/
  • Replies 84
Guest MrLolly
hey jay, i recently did mine and my 93 model 33 has its fill plug on the passenger side
also, no need to buy a special oil pump, just get one of those little plastic pumps that are used for getting fuel out of a can and into the car, cost $6, all you need to do is shorten the collector hose so that it fits into your four litre bottle
rod
https://www.sau.com.au/forums/topic/631-gearbox-oil-change/#findComment-16654
Hiya Guys....
I basically have the same problem as Jay95R33 ... that is for the first couple of changes after you start the car going from first into second .... second gear grinds.... then it stops after a couple of gos....
So my question is ( and feel free to make fun of me :P as I have only had my 95 R33 GTST about two weeks ) Does the skyline have a dipstick for the gearbox ( manual ) ???? I had a look but couldnt find one??? Or is it self contained or something??? Do I just go straight for the dumping of the oil????
Help! :confused:
Brett
https://www.sau.com.au/forums/topic/631-gearbox-oil-change/#findComment-17082
G'day Brett,
Naaa, there isn't a dip stick for the manual box. It's a sealed unit (except for a small breather I think), so your only option is to drain the oil and put fresh stuff in.
You can top it up, but it's best to drain the old.
It really is straight forward. The hardest part was jacking up the car, and then pumping that little pump thing about a zillion times to get the 4 litres in her.
J
https://www.sau.com.au/forums/topic/631-gearbox-oil-change/#findComment-17086
Thanks for that....
Another question.... where is the jack spot for the R33??? I ask because with all my bodykits I dont want to put pressure on something I shouldnt.... ( I had a commodore before and it was dead easy :P )..... I should also go back to the import dealer and ask for a jack as I dont think I got one with the car...
P. S All you Perth guys should put out a message when you organise another cruise .... I would love to be part of a HUGE skyline cruise.... that would be fun .... and a great chance to learn some stuff :)
Thanks Again
Brett
https://www.sau.com.au/forums/topic/631-gearbox-oil-change/#findComment-17091
Cool,
You should be able to use the normal jack spots that are near the sil, your side skirt should stop a little bit before it so you can get your jack in there without causing damage.
Once up, put your axle stands under the chassic rails.
Yeah, go back and get a jack from your dealer, other than being stuck somewhere with a flat and no jack, I think you have to carry a jack by law (stupid hay), but if you get a cop that's had a really bad day he could get you for it.
J
https://www.sau.com.au/forums/topic/631-gearbox-oil-change/#findComment-17125
yeah same with mine when its cold it wont go into 2nd or back to 1st or grinds... unless i pump the clutch in neutral a couple of times... could need oil change i guess? Also this could be unrelated but if i start the car up and its really cold, and reverse, once the clutch starts grabbing sometimes it will squeal very loudly, sounds like its slipping... doesnt happen once its warmed up, anyone know what this could be?
Chris
https://www.sau.com.au/forums/topic/631-gearbox-oil-change/#findComment-19055
Hmmm, the squeeling - does it sound like a bearing squeeling? It could be your thrust bearing on the way out. Not sure.
As for the 1-2 crunching, yepp, that's what mine was doing and the oil change made it all sweet. It was getting bad enough for me to forget about 1st gear for the first few take off's (use second), but after the oil change it goes between first and second like a dream now.
J
https://www.sau.com.au/forums/topic/631-gearbox-oil-change/#findComment-19194
ohhh if i only knew that when i had to change the diff+gbox oil on my escort.. i was under the car with a 250ml sunscreen bottle squirting it in..
thankgod i have patience
Shaun
https://www.sau.com.au/forums/topic/631-gearbox-oil-change/#findComment-19196
Originally posted by thejackal
how often should you change your gearbox oil?
Originally posted by skyzerr33
every 80,000 to 100,000 km's
So if within 11 thousand K's mines done this, is it because
I've been driving it way too hard? :) :burnout:
or was it just crap oil they put in when it was complied? :confused:
(my car has only done 50 thou)
Or is my box on it's way out? :bonk:
https://www.sau.com.au/forums/topic/631-gearbox-oil-change/#findComment-19229
They all seem to do it (crunch that is).
I've changed my oil a few times since I bought it 2 years ago... I use the VMX80 stuff in my car too... Works a treat!
As Jay said, the hardest part is pumping the oil into your gearbox... Man your arm gets tired! :P
A lot of compliance places don't even change the gearbox/diff/brake fluids anyways, just to save a bit of cash... I know the place I took mine didn't. You'll be surprised how much of a difference an gearbox oil change can make!
matt
https://www.sau.com.au/forums/topic/631-gearbox-oil-change/#findComment-20512
With the VMX80 bottles snout i found that a length of garden black hose fits perfectly.
I then held the bottle upside down with the hose attached near the bellhousing and it was pretty easy to fill up.
Well it was easy as I had a Pit to do it in so it may be a little harder laying under the car but still easier than a sunscreen bottle.. heheh
https://www.sau.com.au/forums/topic/631-gearbox-oil-change/#findComment-20714
  • 1 year later...
jayson i had the redline shockproof in mine $25 a L mind u
and now i have the same stuff u have, and mine crunches slightly into 2nd when cold
the redline stuff was great... next time in gonna buy some again
also when i refilled it i poured it through where the gear lever goes... didnt seem to do anything wrong that way... makes life easier i fink
anyone got any probs wif the way i did it?
https://www.sau.com.au/forums/topic/631-gearbox-oil-change/#findComment-397056
You will be suprised how much smoother Nulon G70 gear treatment makes the gearbox with a couple litres of VMX80.
Since I had a VL Commodore that are renowned for diff whines i've used G70. The diff would whine like fark so I slapped a tube of this stuff in and a few hundred km's later the whine was so quiet you had to have the radio off, windows closed and silence to hear the whine.
My old VS V8 5 Speed manual used to crunch a little when cold. I slapped G70 in there and the crunching when cold dissapeared.
Same with the Skyline Box.. grabby feeling when cold is now gone.
https://www.sau.com.au/forums/topic/631-gearbox-oil-change/#findComment-397170
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
