defari Posted July 21, 2010 Share Posted July 21, 2010 hi all I have a 33 gts-t with 86000 on the clock and would like to change the gearbox oil not because there is anything wrong but because I like to change all the oils when I get a new car.I was going to get the synthetic nulon 75w85 ($29.99 per liter) but everyone here recommends vmx80 which is much cheaper. castrol recommend vmx-m 75w85... someone said nissan run vmx80- from the factory is this true? i dont want to run a mineral if there is syn in there already thats all. also the castrol website says 2.8 liters... is this wrong is it infact 3.8 - 4? can you overfill it? i did mine last week, took about 3.5L.. cant really overfill it. Same with my diff oil change, just keep pumping until it starts coming out quicker than you can get it in.. Link to comment https://www.sau.com.au/forums/topic/631-gearbox-oil-change/page/5/#findComment-5357912 Share on other sites More sharing options...
AzN Posted July 21, 2010 Share Posted July 21, 2010 (edited) True. Edited July 21, 2010 by AzN Link to comment https://www.sau.com.au/forums/topic/631-gearbox-oil-change/page/5/#findComment-5357921 Share on other sites More sharing options...
Ninjabread Man Posted July 21, 2010 Share Posted July 21, 2010 It's only going to come out of one hole and the other one is a filler...you can't drain from the wrong hole When filling up, fill through the filler hole until it starts to pour out of the filler hole. Easy! I know but I am going to change the diffs and transfer case oils as well and I heard that the transfer case plug is near the gearbox so I don't want to drain and fill the wrong one with the wrong fluid. Do you guys use a fluid pump thing or just a hose to transfer the fluids into the car? Link to comment https://www.sau.com.au/forums/topic/631-gearbox-oil-change/page/5/#findComment-5358130 Share on other sites More sharing options...
defari Posted July 21, 2010 Share Posted July 21, 2010 i got a hand pump off ebay for like 10 bucks, Link to comment https://www.sau.com.au/forums/topic/631-gearbox-oil-change/page/5/#findComment-5358217 Share on other sites More sharing options...
debmatt09 Posted September 12, 2010 Share Posted September 12, 2010 hey guys im new to skylines. i got r33 series 2. wanting to change diff oil, i brought castrol lsx90. is it ok to put it in? or is it wrong?? cheers Link to comment https://www.sau.com.au/forums/topic/631-gearbox-oil-change/page/5/#findComment-5442486 Share on other sites More sharing options...
