hi all I have a 33 gts-t with 86000 on the clock and would like to change the gearbox oil not because there is anything wrong but because I like to change all the oils when I get a new car.
I was going to get the synthetic nulon 75w85 ($29.99 per liter) but everyone here recommends vmx80 which is much cheaper. castrol recommend vmx-m 75w85... someone said nissan run vmx80- from the factory is this true? i dont want to run a mineral if there is syn in there already thats all.
also the castrol website says 2.8 liters... is this wrong is it infact 3.8 - 4? can you overfill it?
i did mine last week, took about 3.5L.. cant really overfill it. Same with my diff oil change, just keep pumping until it starts coming out quicker than you can get it in..
  • Replies 84
It's only going to come out of one hole and the other one is a filler...you can't drain from the wrong hole :)
When filling up, fill through the filler hole until it starts to pour out of the filler hole.
Easy!
I know but I am going to change the diffs and transfer case oils as well and I heard that the transfer case plug is near the gearbox so I don't want to drain and fill the wrong one with the wrong fluid.
Do you guys use a fluid pump thing or just a hose to transfer the fluids into the car?
  • 1 month later...
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
