its the same on the rb25 as well, not sure about rb20, but lots of boost and injectors reaching their max duty will cause #6 to lean out first, get hot, and melt ..
ways to fix - get your injectors flow tested (and cleaned) and put the highest flowing in #6
i just bought some new injectors for my rb25, billed as 550cc, when i got them the flow test report shows one of them flowing upto 576cc this one will go into #6 !
i've thought about various methods of providing extra cooling to the side of the block as well via ducted air from the front of the car, cant hurt ..
just my 2c
Lots of boost and very high airflow required, I haven't seen the problem until well over 2 bar and 60 lbs of air per minute (700bhp). The problem exists in all log style plenums with an entry at one end and outlets along the log. It is due to air wave pressure build up at the end of the log (the end opposite the inlet). The rear cylinders (5 and 6) get too much air, so honing (enlarging) makes it worse. That's why Nissan tapered the plenum around #5 and #6, this works quite well until the boost gets way outside the design parameters.
The simplest way to over come any minor issue is (when you get your injectors flow tested) to simply put the highest flowing one in #6, the next highest flowing in #5 etc. The 1-2% variation in flow is usually more than enough. You can also adjust the individual injector trim with most aftermarket ECUs (Power FC, Motec, Autronic etc). If you have trim adjustments over 3% then its time to think about changing to a large volume plenum, at least double the capacity of the engine (5.2 litres+).
Hope that helps:cheers:
    • This is a very much loved and well looked after car! - Regularly serviced and maintained - Smooth and reliable to drive - Premium model with Bose speakers, suede/leather seats, and dual climate control - Kenwood Double din DMX7522DABS stereo with USB Mirroring, Android Auto/Apple Carplay, DABS radio - 6 Cylinders 3.5L Engine -Triptronic sports automatic - 11000kms - Pearl White - Registered until August - Small fixable dent on boot and several scuff marks/paint chips.
    • Swapped the injectors around and the misfire followed. I went ahead and ordered the Deatschwerks 550cc injectors and am currently waiting for them to be ship and arrive. In the meantime, I've had my Nistune soldered to the ECU. Tested it, and and tried it out with the software. Everything should be prepared for when the injectors arrive.
    • Yeah they charge a little extra for mods , last year I noted no mods but I did have an exhaust fitted after that so  better to let them know cause these kinds of things can cause the policy to be void if you ever need to claim.
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
