1996 R33 GTST S2 M-spec silver. ONLY owner in Australia, Full service history, Long regio. 68,000ks.
Apexi air filter; Trust blow off valve; HKS front mount intercooler; Trust oil cooler; Cusco oil catch tank; NISMO radiator cap; NISMO front bonnet strut; MINES ECU; Apexi AVCR boost controller; Apexi gagages; Front pipe & dump pipe; HKS high flow cat; Signal carbon fibre cat back; NISSAN rear strut; RSR suspention; NISMO 17*8 front & 17*8.5 rear alloys(worth 3000 grand); NISMO S2 400R bodykit; Carbon fibre bonnet; Carbon fibre GT-Wing (C-west style); Koyo triple core titanium radiator; Excedys sports clutch; NGK spark plugs; Endless brake pads; SONY head unit (MP3) & PIONEER speakers; Central locking alarms (2.5 point).
BD4'S DYNO 200kw, MINES graphic design.
The car was in autosaloon 2004 sydney final battle, this is a real show car. Nice, loud and fast, will get everyone attention.
Must go $29,500 and negotiable, ask for pictures ring 0404763685 Alex DU or E-mail: [email protected]
NO JOY PLAYERS!
https://www.sau.com.au/forums/topic/63185-r33-gtst-s2-m-spec-for-sale/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
