17" Work RS-Z
In Gold colour
To suit R32 GTS-T
F: 17 X 7J +35
R: 17 X 8J +35
5 Holes PCD114.3
Near new, no gutter scrape
Tyres: Yokohama Grand Prix M7R
F: 215/45/17
R: 235/45/17
90% treads on tyres
$1500 + postage within Australia
Stock coming over in 3 weeks.
I have a registered company and an ABN, tax receipt no problem!
https://www.sau.com.au/forums/topic/63204-17-work-rs-z-in-gold-suit-r32-gts-t/
