really?
i can't remeber , i did my first year AGES ago.... hahaha
Yep sure was buddy.
It was briefly covered in one of the PSYC1104 lectures, you know when I was super keen and attended every single lecture.. lol :D
Exactly what I plan on doing this year.. Attend every single lecture. New years resolution. :D
that's what i plan and heard every year! :D
u should be fine, hope i can attend 80% lecture and i should have some pretty good result.
i don't think i have 30% attendence in my whole Uni life :bananaman
my god..
Attendence.... I wasn't a big fan of attending lectures. After all, I mangage first two years of uni with less than 30% attendence...... lectures were either too early or too late for me...
Anyways in third year, I made a change to attend to more lectures.... realised that I have more friends now.... my grades improved.... (more people to "help" me with assignments)... just last year in my fourth year... I only missed about two subjects (or topics)...
I will put in 90% in this semester to come... and see how that goes... in hope to get a job when I finish uni...
Good luck every one in 2005
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
