Turbos
[Turbonetics T66
Ball bearing, Q trim, 0.58 exhaust housing. Polished large compressor housing. Currently on car, made 321rwkw on an internally standard bottom end.
$1800
Trust TD06-25G
8cm exhaust housing, has been reconditioned with new bearings etc.
$1500
HKS 2530 pair
Reconditioned with new catridges. Have zero use since rebuild.
$3500
HKS 2835R
External or internal exhaust housing. Used, good condition. Have a pair of these as well as a high mount manifold if a twin setup is desired.
$1500 each
Exhaust
HKS RB26 low-mount manifolds
With or without crossover pipe. Standard tubular replacement manifolds. One piece runners, exceptional welds and construction.
$1600
HKS R33 dual exhaust system
"Race" exhaust system, proper dual from up pipes to tailpipes. No provisions for cat convertor. One of the best exhaust for lowmount setups. Full stainless steel system.
$700
Apexi RB26 twin highmount exhaust manifolds
Has provisions for one wastegate, RX6 flanges but can be changed to T25/T3 etc.
$1000
Suspension + brakes
AP 6 spot calipers
Can machine adapter to suit Skyline.
$2000
BCNR33 HKS Drag suspension
New in box, fully adjustable with valve rates to suit drag racing
$1500
BCNR33 HKS 4-way Circuit suspension
Top of the line, remote reservoirs. Fully adjustable - used, perfect condition, no leaks or issues.
$1800
Misc parts
Z32 AFMs
In pairs with HKS or Apexi filters, plugs
$700 pair
Q45 AFM - $300
HKS DLI
Type I, new in box. For motors with external ignitor
$800
Trust intercooler
Brand new, twin inlet. 600x300x76mm.
$1500
Spearco water to air intercooler
Brand new, has 2 water pumps. Supports 3000+hp.
$2500
Trust 6 speed gearboxes
2 complete gearboxes. Alot of spares and custom parts.
$10,000 for both
Located in Sydney, will post pics if interested, please PM as I rarely visit the boards anymore.
https://www.sau.com.au/forums/topic/63230-parts-for-sale/
  • Replies 44
RB26 Trust single high mount exh manifold + wastegate
One piece runners, type C wastegate. Can be used with either T66 or T04R turbos.
$1800
HKS RB26 single highmount setup kit
Exhaust manifold and GT wastegate. Can be used with T66 or T04R turbo.
$1800
Could you please contact Louis on 0404 737 906
I would like to purchase one of the manifolds and wastegates if still available asap.
https://www.sau.com.au/forums/topic/63230-parts-for-sale/#findComment-1195142
PowerFC's - deposits taken on both
PowerFC Boost controller - missing pressure sensor + a section of loom, not going to buy replacements ($200 from Greenline) so will just sell the solenoid as a spare.
https://www.sau.com.au/forums/topic/63230-parts-for-sale/#findComment-1195316
What are the specs on the T66.
Was this power made on a RB26? I am wondering what it may be like on a Rb25?
Yeah it was on an RB26 - it's still on the car at the moment. I think it really needs a built engine to make better use of it, the compressor should be good for 700+ flywheel HP so 321rwkw is a bit lazy for it.
https://www.sau.com.au/forums/topic/63230-parts-for-sale/#findComment-1195616
Yeah could be a little large compared to my 2835 ProS. Although it now is running out of puff since I have put GTR cams and valves in my head. I will do a search for more details.
https://www.sau.com.au/forums/topic/63230-parts-for-sale/#findComment-1195727
$700
could you send pictures please
https://www.sau.com.au/forums/topic/63230-parts-for-sale/#findComment-1197148
"PowerFC Boost controller - missing pressure sensor + a section of loom, not going to buy replacements ($200 from Greenline) so will just sell the solenoid as a spare."
FYI for anyone interested, Croyden Autosport in Sydney had a Boost kit without solenoid when I was there the other day :D
There is a bargan there for somone who needs a PFC boost kit. Unfortunatly for me I already bought a new kit!
https://www.sau.com.au/forums/topic/63230-parts-for-sale/#findComment-1197298
Also would be able to sell complete engine package, currently running in a car so you can inspect/dyno/comp check etc.
R32 RB26 base motor
Rebuild 15,000k's ago
N1 pistons, N1 rings, N1 oil pump
Jun crank collar
Apexi cams
Cam gears
700cc injectors
Apexi fuel pressure reg
HKS exh manifold + GT wastegate
Turbonetics T66 turbo
Tuned PowerFC Pro
$12,000 or offer.
https://www.sau.com.au/forums/topic/63230-parts-for-sale/#findComment-1198577
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
