Redline Performance Cruise For The Salvos – Biggest Event Of 2005 13/03/05
REDLNE
 Share
the cruise it going to shikjuku.
BTW my favourite line was this:
we are on show to the country via channel 9 to show them that the modified car industry is not full of hoons and people that care about the community.
apart from that good luck with the cruise. good to see someone trying to do something for a good cause.
  • Replies 121
http://forum.hot4s.com.au/messageview.cfm?...&threadid=30013
Date: 13th March 2005
Meeting point for sydney : P6 carpark
Time: 10:30
Meeting point for central coast : To be advised
Time: 11.00
Meeting point for newcastle: Newcastle Knights stadium carpark where there will be a representative of the cruise in charge there
Time: 11.00
The final destination is at Bateau Bay sports and rec fields (also known as EDSACC).
well i guess that means us coasties will be at edsacc at 1130, no use going to the twinys cause then it would mean going up to warnervale doing
"u" turns and coming back down the free way.
unless we meet up with the newie crew on their way down the freeway.
That's what we've done every other time man... just shoot up the freeway from newy, turn round after the caltex and then come back down the freeway to the caltex going back towards newcastle... it's easy :P
ne more know what time the cruise finishes @ s.o.p cos  i need 2 b  @ the superdome  4.45 pm.
gtrsrule - Not sure when it will finish but as a guess i would say 16:30 to 18:00
I guess we are leaving Sydney @ about 11:00 to meet up @ Wyong @ 12:30, does anyone know?
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
