hey guys, just wondering how do i advance the timing on my r33 gts? i heard that it can become more responsive with the timing advanced. i've got a timing gun in the garage, but this connects to the spark plug lead, so how do i do it for the skyline?
step by step instructions with pictures would be nice :cool:
im not much of an mechanic, just the other day i dropped a bolt into the engine bay and couldn't find it :)
https://www.sau.com.au/forums/topic/6325-how-to-advance-the-timing/
Ha ha, i've done that.
I recomend you get some one to do it for you, like cypher industries or x-speed.
Advancing it to much will cause the car to detonate and ping, can be pretty dangerous specially if you dont have a big front mount.
One way would be to PM DAMQIK, he has whipped up a quick adapter. He should be able to send you some pictures of it.
Basically you remove the COIL and hook up a short ignition lead between the coil and the spark plug. This gives you a lead to hook onto.
Also you will obviously have to remove piping, cover etc off the engine.
Also you will have to remove the front cover off the engine. Sorry I can't explain it more. If you do a search for spark plugs on the forums, you will find detailed info on getting access to your coils/plugs.
Umm if you check meggala's site he has an absolute wealth of info and links.
Regards,
Tim
whatever you do dont just advance the timing or let anyone else advance it just using the crank agle sensor this is not cool wont go into it at length but its not a good idea to do it this way. PLus id be pretty wary of more advamce on a gtst as the have quite a high static comp ratio of 9.0:1 and they are already tuned to 100RON fuel which we dont have so be carefull!!!!!!!!
    • I drive the Tiguan much harder than the Skyline in all conditions, because it just grips and hooks, unlike the R33 shit box
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
