  • Replies 184
We went to the Golden Slipper at Rosehill instead....saw the greatest mare in the world easily win the BMW (kenny do you sponsor that race?) what an awesome sight from an absolute champion.
I'm the one who needs sponsors, not the other way around!
Sanchez, I am saying that it made 770 hp .. but not for long since Theo unfortunately popped the engine.
It popped 'cause somone forgot to do up the harmonic balancer didn't they! This meant it lost belt drive for the dry sump pump and picked up on the bottom end.
But your right.......... I'm glad I don't have to pull it out all the time.
Theo's got wing nuts on it now!
WSID carry on relentlessly about their WORLD CLASS FACILTY and how forking awesome it's supposed to be but they still don't have a carpark that withstands two days of rain.
World Class Facility my left one!
Adrian
Adrian
:werd:
Current weather and forecast looks grim. I don't even think my car will be able to make it for a display at the show and shine, let alone racing. Hopefully the weather gets better by Thursday, otherwise I would imagine that it will be canned for the same reason as last time.
Guest two.06l
Adrian
can't see them running the event....no spectators no profit....cannot see them running event at a loss, they are drag racers not circuit wannabe's
Current radar imagery of any rain in the Sydney area. WSID is located at the junction of the North-south line and the inner circle (just above the second "r" in "Parramatta").
http://mirror.bom.gov.au/products/IDR033.loop.shtml
From BOM 3:41pm today:
"Friday : Shower or two, mainly morning. E/NE winds.
Sydney: 16 24
Liverpool: 13 25
Penrith: 12 25
Richmond: 12 25
Saturday : Fine. NE winds
Sydney: 16 25
Liverpool: 13 26
Penrith: 12 26
Richmond: 12 26
Trend for Sunday, Monday and Tuesday
Warm and dry. Sunday. Cooler SE change Monday and mainly dry.
Abflug i believe i saaw your car at CRD as well what sort of power did she make if you don't mind me asking.
Cheers,Ben.
PS.also have you done many mods and what turbo's are you running?
It made 414awkw . At the moment it has a T88 but that will be coming off soon when the new engine is ready. The car is basically as it came from Japan so we dont know whats inside the engine. The RB20 airflow meters were maxed out so it couldnt be pushed any more.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
