Tailshaft is probably the easiest of all those mods to the car for tech inspection. :cheers:
Good luck to you Paul, and to everyone racing on Saturday. I will be snapping away and taking plenty of videos. I won't be hard to spot. :)
  • Replies 184
Guest two.06l
Yeah a mate was just telling me before you can buy a kit for it. Easy install too
Too easy. Remembr that it must be a certain distance from the front uni. Technicalities...
Where did you put the battery isolation switch? I have a boot mounted battery and my car was painted yesterday, so I don't want to cut any holes in any panels.
Guest two.06l
150mm to be precise...
its poking out drivers side duct in front bar, made a aluminum bracket that is screwed to the metal front bar reinforcement.
DoughBoy will you be racing in anything i forgot to ask the other day.
Paul good luck with getting the car sorted for the race!
Yeah, I'm not sure if I should run the Mitsu L300 in the all motor class, or the Ford Transit in the forced induction one. Ahh such decisions, better check that it's going to pass scrutineering.
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
